Old 05-01-2015, 10:15 AM   #1
73kay
76 c10 on 86 cab issues
Hey fellas found some topics similar but dance around my question. I have a 76 c10 and I replaced the old cab because of rust. I have an 86 on it now but I have encountered a new issues.
1. 86 column wiper wires and trying to use 76 wiper motor. Things just aren't working right when I use the controls on the column. Thinking I need an 80s wiper motor?
2. Light panel/dash mismatch- these are no aligning right. I thought they were backwards compatible with the metal dash frame being the same? So my plan is to remove the old dash from my 76 and replace the 86. I'm a sucker for the old style dash.
3. Hood support pins- they support the back of the hood to rest on when it's closed. It doesn't look like there is a place to screw my old ones in, I think I'll have to measure and drill?
4. Fenders don't really match the cab angles around the lower windshield. The top bolt is a tight squeeze to install it with the fender hole aligning to the cab. I'll try and get some pictures later today. I haven't played with the shims too much yet but I am wondering if anyone else has had this issue?
I appreciate your help, I always heard the cabs where backwards compatible but these little issues I must of overlooked.
Andrew
1953 3100 292 T5
1985 K5 Blazer 350 700R4 208
73kay is offline   Reply With Quote
Old 05-02-2015, 10:53 AM   #2
73kay
Re: 76 c10 on 86 cab issues
No one ever upgraded their wiper or changed out their cab?
Andrew
1953 3100 292 T5
Old 05-02-2015, 12:55 PM   #3
Titomars
Titomars's Avatar
The 86 body does not use rear hood bumpers/supports. The 81 up hinges provide the support.
If I remember right you'll have to upgrade the wiper motor to a 79 or up. There was a design change right around that time.
1977 Chevrolet C/10 Silverado. Step-Side, Factory 454, TH400, 3.73 Posi 12 Bolt.
1975 Chevrolet El Camino. 350, TH400, 3.08 Posi 10 Bolt.
Titomars is offline   Reply With Quote
Old 05-04-2015, 07:23 AM   #4
73kay
Ok thanks for the wiper tip I'll have to see if a newer one works. I wasn't sure.
Andrew
1953 3100 292 T5
Old 05-04-2015, 09:10 AM   #5
KrazyRay
KrazyRay's Avatar
85 and newer has the windshield washer pump in the reservoir. I don't know if that causes problems. Also, I see a lot of these trucks where the fender angle looks off from the windshield.
KrazyRay is offline   Reply With Quote
Old 05-04-2015, 09:49 AM   #6
73kay
Ya I have that weird angle by the windshield too. Tempted to try and fab it to look better but I'm gonna be patient and see if shims can fix it. Lol
Andrew
1953 3100 292 T5
Thread Tools
Display Modes
