Old 05-10-2015, 12:10 AM   #1
77 C-20 Scottsdale
Receiver hitches
Does anyone make a class IV hitch that does not require drilling to install? Some companies say no drilling, but that is totally false in many cases. I was looking at a Reese 37087, which claims no drilling required. I only see four holes in my frame, not the six that are needed. Not even sure if the four holes I have would be a match for the hitch, which would only need two additional holes drilled. Hoping also to find a hitch that will not interfere with the spare tire rack. Any photos/information will be appreciated. Thanks in advance.
77 C-20 Scottsdale is offline   Reply With Quote
Old 05-10-2015, 12:50 AM   #2
JacobSchni
JacobSchni's Avatar
Re: Receiver hitches
ill look tomorrow for number but i bought a reese and it also said no drilling required... that wasnt the case though. i had 6 holes and only 2 lined up the others were too far inside and forward
JacobSchni is offline   Reply With Quote
Old 05-10-2015, 09:30 AM   #3
cadillac_al
U-haul is the hitch experts. If their hitch needs drilling then they all do. There is enough holes in these frames that you wouldn't think it would be necessary, but no big deal if you need to drill a couple holes.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 05-10-2015, 09:49 AM   #4
cdowns
cdowns's Avatar
jcwhitney has a large selection of hitches
hire somebody to drill holes if you aint up to it
Old 05-10-2015, 10:45 AM   #5
77 C-20 Scottsdale
I don't mind drilling holes, I was just hoping to find one that will match at least two, if not four existing holes. Despite my truck having the factory Trailering Special option, it has never had a receiver hitch on it. Hoping also to find one that does not interfere with the spare tire mounting.
Old 05-10-2015, 12:37 PM   #6
tucsonjwt
I have found that most squares have had the spare tire carrier removed because it does interfere with a receiver hitch. I moved the pivot bolt on my stock spare tire carrier forward about one inch and the spare tire just clears the hitch and the exhaust (which I have routed out the sides, not the back.) I think I have a 5,000# Draw Tite hitch but I think the Reese hitches are about the same dimensions.
tucsonjwt is offline   Reply With Quote
Old 05-11-2015, 02:22 AM   #7
bmchevy1979
bmchevy1979's Avatar
Does it have to be a class IV the factory III on my blazer bolts into the factory holes for the outer bumper brackets and another hole near end of frame on both sides I don't have a pickup anymore so I can't check to see if all the holes are there
<Brandon>
1974 Chevrolet K5 Blazer 350sbc/SM465/NP205, dana44 front, corp 14bolt rear with 4.10s and a powertrax locker, custom rear bumper 400sbc in the works.
1981 GMC C1500 stepside 250i6, 3spd, 12bolt with 3.08s 2.5/4drop on 15x10 with 275/50r15
81 GMC C3500 cab-chassis dually with utility bed 350sbc, Sm465, 14bolt with 4.10s nv4500 getting ready to go in
1979 Chevrolet K5 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434096
1976 Chevrolet C10 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434195
bmchevy1979 is offline   Reply With Quote
Old 05-11-2015, 06:18 PM   #8
Zach079xxx
Zach079xxx's Avatar
I got a class 3 Reese tow-power multi fit truck hitch from walmart. 120 bucks said it only fit 88s & up but it fit my 85 with no drilling.
Zach079xxx is offline   Reply With Quote
Thread Tools
Display Modes
