Old 05-18-2015, 11:47 AM   #1
thefaceman
thefaceman's Avatar
Door Rubber Problems
Dumb question: I want to keep my door weather seal from falling off, but have no idea what if any adhesive I should use. Any thoughts or suggestions?
thefaceman is offline   Reply With Quote
Old 05-18-2015, 12:38 PM   #2
65chevysub
65chevysub's Avatar
Re: Door Rubber Problems
I use 3M weatherstrip adhesive. Be careful using it as its kind of runny and if you use too much it gets everywhere and it shows up because its yellow
65chevysub is offline   Reply With Quote
Old 05-18-2015, 12:43 PM   #3
61K10
61K10's Avatar
It comes in black also and apply it the way the directions say.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 05-19-2015, 10:21 AM   #4
thefaceman
thefaceman's Avatar
Old 05-19-2015, 01:31 PM   #5
par4tom
Use some masking tape to mask off the areas you DONT want adhesive...I did that on mine the second time as no matter how hard you try, that adhesive gets on something you don't want it to get on...
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=705185
How to Get Audiophile Sound in 60-66 Trucks
http://67-72chevytrucks.com/vboard/s...=1#post7236896
Building Your Own Speaker Kick Pods
http://http://67-72chevytrucks.com/vboard/showthread.php?t=730495
par4tom is offline   Reply With Quote
Old 05-20-2015, 02:57 PM   #6
thefaceman
thefaceman's Avatar
Picked up the adhesive last night. Gonna give it a shot this weekend. I was thinking I'd put a bead of adhesive into the crease in the rubber itself and then slide it on. Is this a good approach? Thanks.
Old 05-20-2015, 03:28 PM   #7
1963c-10
1963c-10's Avatar
Its what I did when I did my door gaskets a few weeks ago. I used the black 3m weatherstrip adhesive. Placed a nice bead inside the rubber and then ran it around the door frame. Had to go back and spot hit a few areas, then I taped the whole door every foot or so, little more in the corners and bends and let it sit overnight. Has held good for me.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 05-21-2015, 12:54 PM   #8
thefaceman
thefaceman's Avatar
Great. I'm gonna give it a shot this weekend. I'll let you know how big of a mess I make...
Thanks!
66 C/10 LWB
http://i.imgur.com/EcqZpK7.jpg
Old 05-21-2015, 10:05 PM   #9
T and S
T and S's Avatar
Treat it like u would contact cement. Let the 3M set up until tacky on both parts, then assemble - that worked good for me.
If you don't like this pound sand .....
T and S is offline   Reply With Quote
Old 05-26-2015, 12:29 PM   #10
Chevystep
If you've got a 64-66 check this out
http://67-72chevytrucks.com/vboard/showthread.php?t=617703
Chevystep is offline   Reply With Quote
Old 05-26-2015, 11:50 PM   #11
Vortech
Vortech's Avatar
I used the Honda Civic Weather strips as described above, worked great no adhesive.
Vortech is offline   Reply With Quote
Thread Tools
Display Modes
