Old 05-21-2015, 07:08 PM   #1
dannyboy
dannyboy's Avatar
Chevy Factory Build Sheet Info
I bought this 1972 Chevy K20 and digging around in it I found along with other things the original customer build sheet.
Here is the links to decode the sheet, I thought I could post my build sheet but can't attach it. To high tech for me I guess.
http://67-72chevytrucks.com/Chevyear.html
http://www.longroof.info/pdf/rpo.pdf
1972 Chevy K20 4X4
8k Winch
Locker Gears
dannyboy is offline   Reply With Quote
Old 05-21-2015, 10:27 PM   #2
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Re: Chevy Factory Build Sheet Info
Fremont Ca. Represented.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 05-22-2015, 03:14 AM   #3
SS Tim
SS Tim's Avatar
What exactly are you trying to do?
Decode the SPID, the option list on the glovebox door.
or
Decode an actual build/broadcast sheet used to assemble the vehicle (often found in the seat or gas tank cover of Fremont truck).
The VIN and model decoder linked is very basic and an expanded version including GMC pickups can be found here.
VIN/Model Decoders
While your linked RPO code list is quite complete and recent very very few are applicable to trucks built between 67-72. GM often reused codes, several times in some cases.
SS Tim is offline   Reply With Quote
Old 05-22-2015, 08:11 AM   #4
Lokin4AReason
Lokin4AReason's Avatar
do they have for other model year(s) ... ?
this VIN decoder on the forum .. ?
dont want to hear excuses, i want to hear solution(s)
Lokin4AReason is offline   Reply With Quote
Old 05-22-2015, 09:25 AM   #5
dannyboy
dannyboy's Avatar
or
?? Not trying to do anything I was sharing information, I have the original 8-1/2" by 11" Chevy build sheet that the guy who ordered the truck specified what he wanted. For example he did not order the manual chock he had then and they had an option to make that cable a throttle cable, find that on most dash boards.
Of course they used the same codes over and over, why not, that was not the point, the point is I have every detail that made this truck go down the factory assembly line June 1972 in Fremont CA.
I also have the Chevy dealer service order embosser card, they would lay your card down and roll emboss all your info onto any service order.
Yes it's that simple
1972 Chevy K20 4X4
8k Winch
Locker Gears
Old 05-22-2015, 09:35 AM   #6
dannyboy
dannyboy's Avatar
FYI: here is the original email from General Motors answering my question on the build sheet decoder, (please note it says 67-72)
I am sure if they had these records that far back they have others for other years.
Re: 1972 Truck Build records
GM Invoice (vehicleinvoice@gmmediaarchive.com)
4/22/14
To: daniel anderson
Hello Dan,
The links below should help in decoding your vehicle.
Respectfully,
GMMA Team
1972 Chevy K20 4X4
8k Winch
Locker Gears
Old 05-22-2015, 09:55 AM   #7
Keith Seymore
Keith Seymore's Avatar
When you submit a post if you scroll down you will see a "manage attachments" button.
Click that and browse until you see the file you want to attach (the build sheet or order information in this case).
If that doesn't work and you would like to email it to me I would be happy to post it up on your behalf.
keith.seymore@gm.com
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 05-22-2015, 09:57 AM   #8
Keith Seymore
4/22/14
To: daniel anderson
Hello Dan,
Respectfully,
GMMA Team
The reason they provided these links is because they don't have the build information for your specific truck, and the generic info is the best they can do. It was not particularly helpful, since you already know what you have.
I say this to contrast to 1976/1977 and beyond, where you can send the VIN and get the actual invoice, with RPO content and pricing, for that specific vehicle.
http://www.gmmediaarchive.com/
K
1979-1986
1986 - 2019
Old 05-23-2015, 03:57 AM   #9
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Pics would be nice to see...
Old 05-29-2015, 02:28 PM   #10
Keith Seymore
x2. I'd be interested to see the build information you received.
K
1979-1986
1986 - 2019
Old 05-29-2015, 03:03 PM   #11
1972RedNeck
1972RedNeck's Avatar
Challenge accepted...
Would you like a picture of my '72 Chevy, my '66 Ford, Grandpa's '71 GMC, his '65 Ford, or my neighbor's '91 Dodge?
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 06-04-2015, 10:53 AM   #12
Keith Seymore
I had the factory hand throttle mounted under the dash on my red truck for a little while.
It is intended to be used to increase the idle when using a PTO driven appliance, but could also function as a poor man's cruise control.
I used it that way until I installed a proper cruise system via the service parts kit.
K
1979-1986
1986 - 2019
Thread Tools
Display Modes
