Old 05-26-2015, 12:18 PM   #1
dpike97701
dpike97701's Avatar
67 Custom Camper Wheels
I did a search for this, but couldn't find anything definitive.. Hoping someone can shed some light. Recently picked up a 67 1/2 ton Custom Camper.. The SPID calls for 04PO3AA Chromed Hubcaps. A couple of questions. The truck came with the wheels in pics 1 & 2. 16" with 4 nubs. I'm assuming these aren't the original rims. I assume that because in pic 3, the spare, is a 16" with clips and it looks like it's been in the spare tire carrier for quite a while. So, I'm assuming that the truck came with 16" rims originally since it's a Custom Camper. Which are correct? The rim with the clips, or the 4 nubs? Does anyone have an example of the 04PO3AA hubcaps? Did they make hubcaps that will work with the 4 nubs that look like 04PO3AA hubcaps? Is the rim in pic 3 a split rim?
Thanks.
DP
67 Custom Camper (1/2 ton)
69 Custom/10 LWB
51 3100 5 Window
dpike97701 is offline   Reply With Quote
Old 05-26-2015, 01:03 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: 67 Custom Camper Wheels
Thanks.
DP
Yes, that is a split rim. Are you sure it isn't a 16.5 tire? 16.5 is what would have been on the truck originally. Only the '67's and '68's have the inside clips. I think the only optional wheels for '67 & '68 were 16.5 x 8.25. You could get 9.75" wide wheels but I think they were aftermarket.
Here is a picture of the 16.5 x 8.25 wheels on my '68 CST/Custom Camper.
Someone correct me if I'm wrong....
LockDoc
Leon
Old 05-26-2015, 01:17 PM   #3
dpike97701
dpike97701's Avatar
It could be a 16.5" rim. I see no stampings or anything on the rim itself, the tire on it is a 7.50-16.
DP
69 Custom/10 LWB
51 3100 5 Window
Old 05-26-2015, 01:27 PM   #4
LockDoc
LockDoc's Avatar
DP
If the tire is a 16 inch the rim would have to be also.
Here is a picture of the '67 & '68 plated hub caps. '67 had a red stripe and '68 had a black stripe. (not my pictures)
LockDoc
Leon
Old 05-26-2015, 01:36 PM   #5
dpike97701
dpike97701's Avatar
Excellent.. Thanks Leon. Do you know if they made a version of the 67 or 68 hubcap that will work with the 4 nubs instead of the clips? Maybe for a 3/4 ton or something? If they did, I'd just use them on the 16" rims that are on the truck already. Paint the rims black, pop on the hubcaps and call it good.
DP
69 Custom/10 LWB
51 3100 5 Window
Old 05-26-2015, 01:45 PM   #6
LockDoc
LockDoc's Avatar
DP
Not to my knowledge but someone that knows their hubcaps better than me may chime in on that....
LockDoc
Leon
Old 05-26-2015, 01:53 PM   #7
dpike97701
dpike97701's Avatar
LockDoc
Thanks Leon.. You provided a lot of insight.
DP
69 Custom/10 LWB
51 3100 5 Window
Old 05-26-2015, 02:16 PM   #8
LockDoc
LockDoc's Avatar
DP
No problem.
LockDoc
Leon
Old 05-26-2015, 10:34 PM   #9
sodly
sodly's Avatar
That last photo looks like a variation on the 65-66 Custom Camper wheels (although those were 8 lug). The earlier CC wheels were also 7.50 x 16 on a 6" lock ring wheel.
I thought Chevy didn't come out with a 1/2 ton Custom Camper till '69. Or am I mixed up?
WANTED:
* 60-66 Chevy and GMC FACTORY PHOTOGRAPHY (scans) of pickups and carryalls.
Custom Camper Club-- Own a 65-66 Custom Camper? Join us at: http://67-72chevytrucks.com/vboard/g...hp?groupid=117
sodly is offline   Reply With Quote
Old 05-26-2015, 10:38 PM   #10
The split rim would be a 16". These caps come in either 6-lug version for outer nub wheels or clip style for 8-lug wheels. That wider wheel Leon showed is an 8.25 not necessarily Custom Camper wheel that would be the same for a 65/66 or 67//68. All GM clip-style caps for 8-lug wheels interchange
Old 05-26-2015, 10:40 PM   #11
dpike97701
dpike97701's Avatar
I was able to locate the available options for the '67 and the 16" rims were an option. I believe the opposite it true as far as availability, I believe they discontinued the 1/2 ton Custom Camper in 69.
DP
69 Custom/10 LWB
51 3100 5 Window
Old 05-26-2015, 10:58 PM   #12
sodly
sodly's Avatar
I know there was not a 1/2 ton custom camper in the 60-66 era. Only 3/4 ton.
WANTED:
Old 05-26-2015, 10:59 PM   #13
dpike97701
dpike97701's Avatar
Thanks special-K. That's good news.. Now I just have to find a set of the 1/2 ton version. cha-ching! Those are going to cost me.
DP
69 Custom/10 LWB
51 3100 5 Window
Old 05-26-2015, 11:03 PM   #14
dpike97701
dpike97701's Avatar
Maybe just a 67-68 thing, then they realized they had it right before and discontinued them again.. I was honestly surprised (pleasantly) when I went to go purchase this truck.. I expected it to be a 3/4 ton not knowing at the time that they ever made a 1/2 ton version.
DP
69 Custom/10 LWB
51 3100 5 Window
Old 05-26-2015, 11:09 PM   #15
sodly
sodly's Avatar
Hmmm. I've read here on the Custom Camper thread in this section that the 1/2 ton CC only became available in 1969.
WANTED:
Old 05-26-2015, 11:15 PM   #16
dpike97701
dpike97701's Avatar
I thought I read it somewhere. Went back and did a search. This is where I saw it.
http://67-72chevytrucks.com/vboard/s...d.php?t=574900
DP
69 Custom/10 LWB
51 3100 5 Window
Old 05-27-2015, 07:37 AM   #17
The wheels in pictures 1 & 2 are optional 16", which were required on the Custom Camper to allow for heavier rated tires. Custom campers were available in 1/2t until 69.
Old 05-27-2015, 02:00 PM   #18
67chevy1series
67chevy1series's Avatar
Seems to me that the 6 lug 16" split rim shown in picture three with the clips would require the 3/4 ton hub cap, only thing is the lug nut area with the clips doesn't look big enough for the ring on the 3/4 ton cap to fit inside
67chevy1series is offline   Reply With Quote
Old 05-27-2015, 04:50 PM   #19
Layne
Is a split rim, and a lock ring wheel the same thing?
Layne is offline   Reply With Quote
Old 05-27-2015, 05:11 PM   #20
hammersmith
hammersmith's Avatar
Yes. The lock ring keeps the slit ring rim together. That and some either and a touch. I had split ring wheels on a 75 Frieghtliner cab over 10x 20 not sure when they phased them out .Glad when they did the.
hammersmith is offline   Reply With Quote
Old 05-27-2015, 10:42 PM   #21
sodly
sodly's Avatar
Not sure how rare 1/2 ton Custom Campers are in Chevys (did GMC offer one, too?) but Ford also offered a half ton F100 Camper Special. I happen to own one (you can see it in my gallery) and I know they are very uncommon. I've only ever seen a handful. I suspect it was the same story for the light duty Chevy CC. I believe Ford phased out their 1/2 ton CS after 1967 or 68 so they only made a light duty CS for 2 or 3 years, probably due to lack of demand, I suppose.
WANTED:
Old 05-28-2015, 09:40 AM   #22
60-66
60-66's Avatar
Posted this info in the for sale section on another post. Looks like it would be helpful here also. The far left hubcap is for half ton nub 15 and 16 inch 6 lug nub wheels and center hubcap is half ton Clip wheels 15, 16, 16.5 and 17.5 6 lug wheels. Far right is 3/4 ton and one ton with the larger hubcap ring inside for 16 , 16.5, 17, 17.5. and 19.5 as long as they are 8 lug wheels.
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
Old 05-28-2015, 10:21 AM   #23
Layne
Thanks!
Old 05-28-2015, 08:14 PM   #24
factorystock
factorystock's Avatar
Great post by 60-66. Anybody with a pre '69 pickup should study those photos before purchasing any hubcap. They all have the same styling and look the same from the front, but there are 3 different back sides. Watch out for wheels also, they often the most changed out item on any old pickup. The first photo is the period correct 16" wheel, the second photo is a '71 and newer disc brake wheel. Both will accept the original PO3 hubcap (chromed version of the painted hubcap on far left side above). Hard to time date the lock ring wheel, IMO, it is overkill for a 1/2 ton pickup anyways. The Custom Camper option between '67-'72 is basically a beefed up suspension option, a pale comparsion to the original '65-'66 custom campers, which had several comfort and appearance items included in the package. With the series 10 C.C. option, I believe the 7.00-15 was the tube type tire on 3 piece heavy duty lock rim wheels, the 6.50-16 and 8-16.5 were tubeless tires on 1 piece rims.
factorystock is offline   Reply With Quote
Old 05-28-2015, 08:26 PM   #25
sodly
sodly's Avatar
Hey, Factorystock.... you'd know this. Was the C10 custom camper only available 67-69?
WANTED:
Thread Tools
Display Modes
