63 Chevy C20 my first truck!
Re: 63 Chevy C20 my first truck!
Welcome and always glad to see a new 63 added to the forum. Great looking truck. Any plans for it?
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
Post Whore
![]() Join Date: Mar 2013
Awesome truck!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
![]() Join Date: Jan 2015
digging the 8-lug speedway wheels
* Call me NOT the website number* Justin Novick (773) 303-8251 Sales/Support Entropy Radiator / Engineered Cooling Products "The Sexiest Radiators For The Sexiest Hot Rods" - www.EntropyRad.com www.speedcooling.com |
Very nice. Looks very rust free.
Thanks everyone! Its a California truck. But it does have a few holes on top of the rocker that i just discovered while trying to remove the door weatherstrip. Damn the luck. The truck is super solid. A few tiny holes inside the bed, all very minor stuff. I was going to put door seals and vent window seals in today, but I have to deal with this rust first!
I got the truck with these wheels and tires. I like them, but sadly they will not be used. I found a 12 bolt from a 71 with 5 lug axles. So a front end swap will also be on the agenda eventually. |
![]() Join Date: Feb 2015
Looks amazing!
I really need to crop those pictures... haha
#12 | |
![]() Nice truck. |
#13 |
Hahaha. I finally got that one!
I would love to stay with the 8 lug axles and big eaton rear, but I'd like her to cruise a little better! So might as well go the 5 lug route... |
#14 |
I've officially started "building" the blue turd. (I need a good name for this truck... old blue is going to cut it)
Plans are to leave the "patina" but clean up everything else. The truck will be converted to five lug rear and drop spindles with disc brakes up front. My goal is to keep it driveable until winter sets in, then take everything of the frame and restore all the running gear. I'd also like to paint the bottom of the cab, inner fender, firewall, and engine. I'm also planning on flipping the rear bumper and raising it a little higher. A hidden hitch will also find its way in there. |
#15 |
Well, first thing is first I guess. Started with some weather stripping a shile back and discovered some rust under my sill plate! My California truck isn't acting very Californian. Anyway, that was last week so I ordered two rockers. I'm not using the whole thing so I scavenged the bottom half to make an inner patch. Its all ready to start welding in, but that will be for tomorrow.
#16 |
#17 |
#18 |
It's been a while since I've been on here... Still lurking, but nothing significant to post. Just kept the truck running with only the necessary repairs until now. WINTER! I had a ton of fun with this beater over the summer, the most fun I've ever had in a vehicle! Here is a few pics
![]() My wife by the truck. I was up on scaffolding siding my garage... ![]() My wife and son waiting to get out of our local weekly cruise in. ![]() I couldn't not take a picture! Anyway, now time for some work... |
#19 |
![]() Here is how she sits now. ![]() Sad looking! My plan for the winter is to take everything apart, sand blast and paint my frame,suspension, engine, and engine compartment. I'm swapping to 3.08 rear end out of a 71 c10, early chevy c20 to c10 spindles, and 4 wheel manual disc setup. Not doing anything to the body besides fixing a few pinholes, maybe not even that. First thing I had to do was make some rear cab mounts to replace the crappy vulcanized rubber mess. ![]() An old wood chisel works well for getting the rubber off. ![]() I chiseled the old cage nut off the top side and fitted the rear bushing with a piece of 3/16 steel that I drilled a hole in big enough for the inner sleeve. ![]() Then I made a template out of cardboard for the gussets. |
#20 |
![]() Viola! I tacked the gussets in place until I can remove the whole cab and fit a nice little plate to the backside. Then I will fully weld everything before sandblasting. By the way, I should mention I did all of this with the box still in place, and a jack adjusting the level of my cab. I just went off the body lines, good enough for me. |
#21 |
Post Whore
Like the new cab mount idea. Glad you had fun with yours over the summer.
#22 |
#23 |
#24 |
Post Whore
Boy you work fast. lol
#25 |
Thread Tools | |
Display Modes | |
