Old 06-01-2015, 03:03 PM   #1
Fourdy
'64 gmc park lights
I have searched but can't seem to find how to remove the park light housing from the hood. I bought a replacement hood and have to use my original housings an.
Thanks in advance.
Fourdy
Fourdy is offline   Reply With Quote
Old 06-01-2015, 04:30 PM   #2
1963c-10
1963c-10's Avatar
Re: '64 gmc park lights
GMC are totally different than the chevy version.....they have 4 small clips built on the housings that hold them in place.
Disconnect the park light bulb and wiring from the housing and you should be free to remove the assemblies. A flathead screwdriver should be able to access the small tabs on the lens assembly from inside the hood. If I remember correct, GMC riveted the lenses to the assemblies originally
Check out this post #304 Link: http://67-72chevytrucks.com/vboard/s...306951&page=13
This pic shows the mounting clips
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 06-01-2015, 05:02 PM   #3
Fourdy
Thank you. I should have them out soonly.
Fourdy
Old 06-01-2015, 07:50 PM   #4
duallyjams
duallyjams's Avatar
http://67-72chevytrucks.com/vboard/s...=643920&page=2
post 34
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 06-02-2015, 02:50 AM   #5
BigDan3131
BigDan3131's Avatar
FYI their a b*tch to remove if that area wasn't kept clean. I nearly tore mine apart getting them out.
Custom Painter/Restoration Specialist
1965 GMC 3/4 Ton LB SOLD?
1964 Chevy El Camino in full restoration
1991 Chevy S10 288K+ miles 2nd Owner SOLD
2020 RAM 1500 Warlock
BigDan3131 is offline   Reply With Quote
Old 06-02-2015, 09:50 AM   #6
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
http://6066gmcclub.com/gmcguy/ParkLamp.html
check out this write up as well.
Old 06-02-2015, 12:26 PM   #7
OldGMJon
OldGMJon's Avatar
Wink Re: '64 gmc park lights
cool write up about the GMC blinkers/running lites...thanks
Projects:
65' Chevy C10 swb (rebuilt chassis)
65' Chevy Panel swb
64' Chevy C30 flatbed "above" 80' C30 "beneath")
Parts:
66' GMC 2503 & 65' GMC I1500
OldGMJon is offline   Reply With Quote
Old 06-03-2015, 10:38 PM   #8
Fourdy
Thanks everyone. I got the light buckets out using 2 screwdrivers and a small hammer. Fortunately I saved the old gasket because the new replacements are mis-shaped and would be very difficult to stretch and get all the rivets in. Old ones were still pliable and look/feel great with some hot water and soap.
Again, thanks
Fourdy
Old 06-04-2015, 08:19 AM   #9
1963c-10
1963c-10's Avatar
Glad it worked out for you Fourdy!!!!!!
Thread Tools
Display Modes
