06-01-2015, 09:29 PM | #1 |
Gauge issues. 85 C10
I've posted on here about my gauges before but no luck, so lets try it again.
Working gauges 1 - Clock 2 - Speedo 3 - Gas (after new sending unit was installed) NON-Working gauges 1 - Oil pressure ( pegged ) 2 - Temperature ( pegged beyond max ) 3 - Volt ( Also pegged ) Heres my baby, last week at a car show / parade [/url] Off topic, but I also made some custom armrest trim too! What you guys think?! [/url] Guessing its a bad ground, but I have no idea where/how the cluster grounds. Can I add a manual ground, like some sort of wire..? Ever since I've had the truck the gauges haven't worked. I installed a set of mechanical gauges 3 days ago, but I really want my cluster to work. And honestly, if it is a ground, I hate to drive it knowing it could go downhill and burn. What should I look for? What color wire, if it is a wire, is the ground wire? How hard is it to remove the whole cluster without screwing up the speedo cable and all that goodness.. Any help would be greatly appreciated, thanks guys. |
06-01-2015, 09:41 PM | #2 |
Re: Gauge issues. 85 C10
Does your oil and temp gauge move at all? If so, I would replace the oil pressure sending unit located next to the distributor. Also, replace the temp sending unit located on driver side cylinder head. I did both and my gauges work correctly now.
06-01-2015, 09:51 PM | #3 |
Oil pressure is half way when key is off then pegs once running. My mind is blown.
06-01-2015, 11:35 PM | #4 |
78K & 79C Jimmys
Hi was it born a gauge truck?
straight Black is usally for ground. I swapped my 78 over to gauges,I had to move wires in the plug but the main ground joint is about a foot from the cluster plug. some people swap and don't change the senders. any recent wiring you know of?
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
06-02-2015, 09:22 AM | #5 |
Your truck has a clock?
Tony Nicholas @ Midwest Metal Masters 1953 Chevy 3100 392 Hemi w/727 & 9” Ford 1985 Chevy C/10 6.0L 4L80 373 locker |
06-02-2015, 11:06 AM | #6 |
It's the original cluster as far as I know. The man said one day they just quit working he thought it was over heating ( pegged temp gauge ). It does have a 96-98 350 crate somewhere in those years he said. Original 305 was weak and old from the person he bought it off of, so he bought a crate around those years above. If its in 97 like he thinks, I would've been 3 turning 4 years old!
Key turned off Key turned on Here's my Quartz clock! Lastly heres my mechanical gauges, oil pressure isn't hooked up because I cannot reach it without removing distributor, vacuum lines are in the way or something, IDK what I'm looking at. My girlfriends dad says thats it. Last edited by Zach079xxx; 06-02-2015 at 11:20 AM. |
06-02-2015, 11:48 AM | #7 |
Pretty cool! Just found out my truck was built in Oshawa Canada! I'm from Virginia and the story goes a mennonite farmer bought this truck new in 85!
06-03-2015, 12:01 PM | #8 |
Any help?
06-03-2015, 11:24 PM | #9 |
Moderator
Temp gauge nailed at the top is usually a shorted sender wire or the wrong sender.
Oil pressure nailed at the top is a cut or unplugged sender wire, the wrong sender, or Teflon tape insulating the sender threads. Try grounding the sender wire. If everything is wired properly it should drive the needle to 0psi. Volts nailed at the top is??? Check the power and ground splices to the gauge cluster wiring. John (motornut) has posted pictures of these splices several times.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
06-04-2015, 02:31 AM | #10 | |
Tried finding pics can't seem to find em!
How do I remove the cluster? I tried to today & I cannot get the speedo out, feels like I'll break something. And honestly I don't feel like j know what I'm doing lol Quote:
06-04-2015, 09:05 AM | #11 | |
78K & 79C Jimmys
there are a couple of bolts to take out, holding the white shell in. It kind of sits behind the lower steel lip,it wiggles out look up behind and you need to push the speedo clip in towards the cluster,to release the cable. the cluster plug is back there if you can reach it,other wise you usually can get it when it's out. and some have a fiber optic cable run from the cluster to the ashtray.
06-04-2015, 09:13 AM | #12 |
78K & 79C Jimmys
so they did work at one point?
wondered if the donor had idiot lights,maybe didn't change the senders? any pic of the senders? does your battery drain down?
06-04-2015, 10:56 AM | #13 |
They never worked for me. The man said they just acted up one day and he never bothered with it. But you never know honestly.. Story goes it as an original 305 and he bought a 350 crate. It has to be a ground! If I pull the fuse when the key is off and move the pegs somewhere as soon as I put it back in and turn the key it will go back all the way up. Is the cluster worth taking out? Will I be able to see the problem? I'm 20 years old and this is my first major project. I don't wanna screw it up. I had everything out last night but the speedo cable I couldn't figure it out.
Here's a picture of the sender. Don't judge my oily beauty. Last edited by Zach079xxx; 06-04-2015 at 11:19 AM. |
06-04-2015, 11:16 AM | #14 |
78K & 79C Jimmys
it's tricky to get the cluster out but once you figure it out, you will know it
IIRC-If I Remember Correctly some years the choke was wired to the oil sender,for safety. later FI wired the oil sender to the fuel pump. wondering if your sender may be feeding.....something
06-04-2015, 12:14 PM | #15 | |
Moderator
06-04-2015, 12:58 PM | #16 |
Yeah I know. But thanks I'll check out the wire. You outta see see my oil pressure sender. Mines so hard to get to because the dizzy & vaccum lines
06-04-2015, 04:55 PM | #17 |
78K & 79C Jimmys
here is the one i replaced and the ones i used,with these ones the ez way to tell,there is quite a size difference.
06-04-2015, 05:22 PM | #18 |
Moderator
The oil gauge sender is buried just behind the intake manifold on the driver side. GM needed a 1/8npt extension & a 45degree elbow to fit em.
06-04-2015, 07:53 PM | #19 |
I'll take a picture tomorrow and show you guys.
Thread Tools | |
Display Modes | |
