Old 06-04-2015, 07:40 PM   #1
SnS C10
SnS C10's Avatar
so I pulled the head and....
On my 292 straight 6 in my 64 c10 I just bought, i pulled the head because of slightly milky oil. The coolant level was still full. So, the two rear cylinders have water residue in them and lots of wet carbon. Problem is, the block and head gasket look fine. Any ideas??
SnS C10 is offline   Reply With Quote
Old 06-04-2015, 07:59 PM   #2
jtrichard
Re: so I pulled the head and....
clean it up good /new gasket and hope for the best
jtrichard is offline   Reply With Quote
Old 06-04-2015, 08:11 PM   #3
1976gmc20
Yeah, that was my first thought. I replaced the gasket on my old 230 in four hours flat and that was with a pounding headache from a concussion (logging incident). So it's not a lot of wrench time to risk.
The only thing is that it might be worthwhile to make sure that the head is okay while it is off.
Current/past Chevy/GMC trucks:
1958 Chevy C-60; 1965 GMC C-50; 1965 Chevy C-10; 1971 Chevy K-10; 1973 Chevy K-20; 1976 GMC C-20; 1977 Chevy C-10 Suburban; 1980 Chevy K-10; 1989 Chevy K1500; 1991 GMC V1500 Suburban; 2016 Chevy K2500 HD
Other vehicles: 1988 Jeep XJ; 2011 Toyota 4Runner
1976gmc20 is offline   Reply With Quote
Old 06-04-2015, 09:04 PM   #4
66Gilbert
1966 Crew Cab & 4X4 Fanatic
66Gilbert's Avatar
Need to have the head magnafluxed to check for cracks. Worse case scenario you have a cracked cylinder or two. Most likely will be a cracked head.
66Gilbert is offline   Reply With Quote
Old 06-04-2015, 09:23 PM   #5
SnS C10
SnS C10's Avatar
I noticed the gasket doesn't seem to make even contact along the cylinder deck. Going to bring the head to work, clean and check for squareness tomorrow
Old 06-04-2015, 09:31 PM   #6
TJ's Chevy
TJ's Chevy's Avatar
Sometimes you can't tell if it was a blown head gasket even though it was. If the rear two cylinders were the ones that had wet carbon then you'll want to look closely at the water ports between those cylinders. Have the head checked like your doing and go ahead and surface the head and block while you have it out.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 06-04-2015, 09:43 PM   #7
SnS C10
SnS C10's Avatar
Is there a way to check between the 2 rear cylinders ? Or just visually look as best I can? I'm planning on leaving the block in the truck unless i find a major problem
Old 06-04-2015, 10:55 PM   #8
1976gmc20
Yeah, that's what I would do
Worst case scenario you're out a couple hours putting it together and the price of a head gasket. Those 292s are pretty tough and tolerant engines. They have to be, if I can rebuild one and have it come out right
Old 06-05-2015, 09:48 AM   #9
TJ's Chevy
TJ's Chevy's Avatar
I'd just visually look. Get a nice bright light and check for cracks. Most of the time you can make out hair line cracks. How do the cylinder walls look? I ran my 292 as low as 90 pounds of compression and it ran great. haha They are one heck of an engine.
Old 06-05-2015, 11:31 AM   #10
Chevy Fleetside
Chevy Fleetside's Avatar
I would think that if it ran smooth when you fired it up and there were no misses or rough idle, you are probably doing pretty good. If a cylinder was cracked it would smoke immediately and would have a rough idle/miss. I know I cracked a cylinder before, and it is not pretty.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 06-05-2015, 11:57 AM   #11
awbrown
Thats why I have always changed the oil , or at least drained it and replace it with some used oil before starting a motor I dont know anything about , remember ,water sits on the bottom , right where the oil pickup is so the minute it starts it pumps water all through the engine ..
awbrown is offline   Reply With Quote
Old 06-05-2015, 12:52 PM   #12
GRX
GRX's Avatar
All good advice above. Too late now since the head is off. When encountering such problems I always check head bolt torque with a torque wrench before removal to see if any are below spec. Best of luck
GRX is offline   Reply With Quote
Old 06-05-2015, 02:18 PM   #13
SnS C10
SnS C10's Avatar
Thanks for the good advice guys
Thread Tools
Display Modes
