Old 06-05-2015, 09:49 AM   #1
canadian_diesel1964
Anyone used 6 x 5.5 to 5 x 5 wheel adapters?
If you have pics of how far they push the wheels out would be amazing..thank you!
canadian_diesel1964 is offline   Reply With Quote
Old 06-05-2015, 10:07 AM   #2
joedoh
joedoh's Avatar
Re: Anyone used 6 x 5.5 to 5 x 5 wheel adapters?
anything with a pattern change is a minimum 1.25" thickness, but because the 5x5 pattern will lay on top or close to two of the 6x5.5 studs, I would bet it would have to be a two piece adapter and 2" would be the minimum thickness. I havent actually seen any pattern changers that go from a 6x5.5 to 5x5 but I am sure they exist.
a two inch adapter will push the wheel out two inches. if you are working in backspace, subtract two inches so a 5 inch backspace with the adapter will have 3 inches backspace. if you are working in offset, subtract 49mm of offset so a +12 will become a -37mm offset.
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
Old 06-05-2015, 10:19 AM   #3
canadian_diesel1964
Great info thank you...I've only seen them in 2" your right
Old 06-05-2015, 10:39 AM   #4
lolife99
67-72 parts collector,…
lolife99's Avatar
These are some crazy scarey adapters.
They are 2-piece and are actually bolted together with bolts.
I would not run these.
Keith
Convert to disc brakes.
Old 06-05-2015, 10:42 AM   #5
lolife99
lolife99's Avatar
http://www.ezaccessory.com/Wheel_Ada...6550-5500s.htm
Keith
Old 06-05-2015, 11:11 AM   #6
canadian_diesel1964
I can see how this is an area of concern
Old 06-05-2015, 11:58 AM   #7
65chevysub
65chevysub's Avatar
I sent my original axles back to Moser Engineering and had tem change from 6 to 5 lug. Been like this since 1996 and no problems.
65chevysub is offline   Reply With Quote
Thread Tools
Display Modes
