Old 06-05-2015, 06:16 PM   #1
flood1964
front disc brake conversion 65 c-10
I'm looking for advice on a spindle (not a drop spindle) that will be compatible with the DJM control arms that I'm using to replace the factory control arms on my 1965 c-10 fleetside. The new DJM control arms are going to give me a 5" drop. So, I need a factory height spindle and a disc brake kit as well. If anyone knows of a brake kit with the spindles included please advise. Any help will be appreciated.
flood1964 is offline   Reply With Quote
Old 06-05-2015, 06:52 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: front disc brake conversion 65 c-10
Almost ALL drop spindle manufacturers sell a stock height 63-70 disc brake conversion spindle. They will be a direct bolt on replacement for your drum brake spindle.
Look at summit racing.
Keith
Convert to disc brakes.
Old 06-05-2015, 06:52 PM   #3
Slow Build
Slow Build's Avatar
I think those lower control arms lower the front 3". I'm not a big fan of lowering front control arms because they just lower the bottom of the spring bringing the spring bucket closer to the ground. If you were to use a drop spindle with them it would be way worse.
As far as spindles go you can use a stock 72 disc brake spindle as long as you have the right ball joints in the control arms.
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline   Reply With Quote
Old 06-05-2015, 06:54 PM   #4
lolife99
lolife99's Avatar
http://www.summitracing.com/search/d...3%2B4294945824
Keith
Old 06-05-2015, 06:58 PM   #5
lolife99
lolife99's Avatar
71-72 or 73-87 require a balljoint change like you said.
But the tie rods have to be changed also.
It get's more complicated because the 63-70 outer tie rods are LH thread and 5/8".
The 71-72 or 73-87 outer tie rods are rh thread and 11/16"
Direct bolt on spindles is the easiest.
I too HATE drop pocket a-arms like the ones DJM makes.
This is outdated lowering components.
There are better safer ways to lower your truck.
I suggest drop spindles and stock lower a-arms also.
Keith
Old 06-05-2015, 08:06 PM   #6
flood1964
Hey Keith,
Do you have any recommendations on a front and rear drop and disc brake conversion?
Old 06-05-2015, 08:10 PM   #7
lolife99
lolife99's Avatar
Originally Posted by flood1964 View Post
Hey Keith,
I like using ECE for 60-72 trucks.
Give them a call before you decide to go anywhere else.
These guys know these trucks.
Superior customer service to!
www.earlyclassic.com
Keith
Thread Tools
Display Modes
