Old 06-07-2015, 11:27 AM   #1
Tahiti or Truck
Tahiti or Truck's Avatar
Lower control arm differences??
I have a 66 C20 with cast lower control arm shafts. While I had the motor out I noticed that the lower control arm shaft mounting bolts look like they are placed in the same location as the newer 67-84ish on the crossmember. I would like to do the caster mod of relocating the lowers forward to increase caster to a set of newer style lowers. My question it can I order the saddles, locating pin and u-bolts from LMC and simply bolt them in? That seems a whole lot easier than replacing the cross member.
Cheers,
Vic in SoCal
BUILD PICS ----> www.1966gto.shutterfly.com
May the Karma Gods meet you half way...
Tahiti or Truck is offline   Reply With Quote
Old 06-08-2015, 12:07 AM   #2
Captainfab
60-66 Nut
Re: Lower control arm differences??
Adding the saddles to accept the round lower control arm shafts is not as simple as it may sound. They will have to be positioned exactly in the correct location, otherwise you will never get a proper alignment.
Old 06-08-2015, 12:31 AM   #3
Tahiti or Truck
Yea. I guess that's what I am asking. Will the stock holes for the cast lower control arm shafts on my 66 cross member properly bolt up and locate a bar type lower control arm shaft??
Cheers,
Vic in SoCal
Old 06-08-2015, 12:46 AM   #4
Captainfab
60-66 Nut
The original lower control arm mounting holes in a '63-'66 C20/30 front suspension crossmember will not work for mounting a round control arm shaft typically found in the '63+ C10's and the '67+ C20/30's.
The short answer is, no that will not work. That is why I always say that the crossmember needs to be changed when changing to the round LCA shafts.
Thread Tools
Display Modes
