Old 06-11-2015, 08:45 PM   #1
D-rock1981
D-rock1981's Avatar
Can't catch a break
I was supposed to go get some new rims and tires for the truck, but alas, something is wrong again. The truck barely turns over, it was working fine till I put a new steering column and some suspension pieces in. New battery, cables are less then a year old, and starter is about 6 months old. Got fed up, said some nasty things, you know the drill. So now I will have to do a voltage drop test tomorrow when I bring my power probe home from work. If it's not one thing it's another.
D-rock1981 is offline   Reply With Quote
Old 06-11-2015, 09:45 PM   #2
Jurassic-1
Jurassic-1's Avatar
Re: Can't catch a break
I had a similar issue with the neighbors 68 Firebird it would try to crank then would not. put a booster on it. It would start then nothing after changing solenoids and checking wires 3 hours later I wiggled the battery terminal on the brand new cable and the molded end was bad. I wiggled it out about 1/4 inch and it turns over like crazy. Turns out new cable is defective.
Jurassic-1 is offline   Reply With Quote
Old 06-11-2015, 09:50 PM   #3
D-rock1981
D-rock1981's Avatar
I have a feeling in might be cable too. There both new, but I did get them from autozone. I will probably go get some welding cable and make new ones just for the piece of mind if nothing else!
Old 06-11-2015, 10:30 PM   #4
D-rock1981
D-rock1981's Avatar
Ok. So I just remembered I broke my engine ground strap when I was installing my sway bar�� completely forgot about it.
Old 06-11-2015, 11:30 PM   #5
Jurassic-1
Jurassic-1's Avatar
Check voltage at the starter. Where is the Negative cable grounded?
Old 06-11-2015, 11:42 PM   #6
D-rock1981
D-rock1981's Avatar
Negative is grounded to frame. Pretty sure is my broken engine to chassis ground strap. I'll put a new one on Saturday and try again
Old 06-12-2015, 12:07 AM   #7
Jurassic-1
Jurassic-1's Avatar
Yes that may be it. Usually I ground to the engine and use aux ground straps on valve covers and a large one to the frame.
Old 06-12-2015, 12:12 AM   #8
mrdurden
Hopefully it's just the ground strap...good luck.
'67 2wd LWB Fleetside
'71 4wd LWB Fleetside
mrdurden is offline   Reply With Quote
Old 06-12-2015, 12:26 PM   #9
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Ground your battery to the engine. Not the frame.
Make sure your ground straps from the frame are connected to the engine.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 06-12-2015, 02:26 PM   #10
D-rock1981
D-rock1981's Avatar
Engine ground strap fixed it.
Old 06-12-2015, 02:29 PM   #11
michael bustamante
michael bustamante's Avatar
good deal
1967custom
michael bustamante is offline   Reply With Quote
Old 06-12-2015, 07:41 PM   #12
mrdurden
Great! Now you can get those new wheels and tires...right on!
Old 06-12-2015, 09:33 PM   #13
You did catch a break after all!
Old 06-12-2015, 10:51 PM   #14
franken
Not to beat a dead horse, or to beat a still not dead electrical fallacy, regardless of what GM did, the battery should be grounded to the block via the big - cable, and the starter powered directly by the big + cable.
The only purpose of those big cables is to power the starter while cranking.
franken is offline   Reply With Quote
Old 06-13-2015, 10:25 AM   #15
Jurassic-1
Jurassic-1's Avatar
I agree I also added a woven large sized ground strap and attached it from the motor mount bolts to the frame it is clean looking and requires a 6-8 inch strap. Glad to hear yo found the problem.
Old 06-13-2015, 10:31 AM   #16
D-rock1981
D-rock1981's Avatar
I have it to the frame and an equal size cable coming from the same ground point to the engine.
Thread Tools
Display Modes
