Old 06-11-2015, 09:34 PM   #1
D-rock1981
D-rock1981's Avatar
How to fill molding holes
Figured I would try and contribute something to the forum for what it's worth. I'm doing this all from my phone so it may or may not work! Lol. I work at a hot rod shop in Denver, and this is how I fill up molding holes.
Here is the hole we're going to fill. This is on a Plymouth fury. Using a scotch Brite roloc I prep the area and drill it out slightly bigger to fit the plug we're going to use to fill it.
This is the punch I use to make the plug
The punch creates a divot in the plug. I set it on an anvil and tap it with a hammer to flatten one side. There will still be a small divot on the other side. This is the side that goes out.
I use a piece of tape on the backside to hold the plug for a quick tack. It does burn the tape, so be quick.
One quick take. I remove the tape, then using a hammer and dolly I will tap the plug and get it flush.
Next it's welded up. I tig weld, but mig or gas is also acceptable. Just remember when mig welding it will be hard to hammer and dolly to a metal finish. The mig welding wire is harder then the surrounding metal and is prone to cracking. Remember that divot in the plug? Put a little tack on top of that to fill it up. I do this because I found when putting the plug in the other way the metal got way too thin in this area so I like to fill it up with weld.
Next I use a 60 grit roloc to knock down the weld. I don't take it all the way down, notice you can still see we're the ends of the weld are.
Next I will planish out any distortion with a slapper file and a dolly. Then finish with a scotch Brite roloc.
D-rock1981 is offline   Reply With Quote
Old 06-11-2015, 09:41 PM   #2
jjzepplin
jjzepplin's Avatar
Re: How to fill molding holes
Nice work! I have heard of this slapper file thing but have never seen one. Could you post a pic?
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 06-11-2015, 09:46 PM   #3
D-rock1981
D-rock1981's Avatar
I'll try to remember when I get to work tomorrow. I made it, just a flat file with 2 bends in it. It's used in place of a hammer. Just a personal preference. The file will put little marks in the steel and you can see where you low spots are. (The areas without marks)
Old 06-11-2015, 10:31 PM   #4
GRX
GRX's Avatar
Good work. These type of threads can be too far & in between sometimes. Thanks for taking the time to share here.
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed.
GRX is offline   Reply With Quote
Old 06-11-2015, 11:32 PM   #5
Jurassic-1
Jurassic-1's Avatar
That is a new one for me. I will have to try that.
Jurassic-1 is offline   Reply With Quote
Old 06-12-2015, 12:10 AM   #6
White70C20
White70C20's Avatar
I am taking classes in Automotive Restoration at a college in Kansas. Our sheet metal professor told us about slapper files, but he himself uses small body shop hammers. I will be graduating this next spring ('16) and will be out on my own working in a shop. I too would like to see what you have used as a slapper file.
White70C20
1970 Blue C20 - 250, 4 speed
1985 Ford Thunderbird
2005 Pontiac G6
White70C20 is offline   Reply With Quote
Old 06-12-2015, 07:02 AM   #7
7tee
7tee's Avatar
Very nice work, thanks for sharing...
7tee is offline   Reply With Quote
Old 06-12-2015, 07:32 AM   #8
Bigdav160
Bigdav160's Avatar
I saw that technique in a Ron Covell video. MIG doesn't work as well because the wire just pushes the plug out of the hole. TIG works though.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 06-12-2015, 08:23 AM   #9
RodnRudy
RodnRudy's Avatar
For those who don't have a punch to make the plugs, Ron Covell sells an assortment of plugs of different diameters for that purpose. Saved me a bunch of time trying to make them when filling firewall holes etc.
RodnRudy is offline   Reply With Quote
Old 06-12-2015, 08:25 AM   #10
Lokin4AReason
Lokin4AReason's Avatar
nice and simple approach =0)
dont want to hear excuses, i want to hear solution(s)
Lokin4AReason is offline   Reply With Quote
Old 06-12-2015, 11:21 AM   #11
alsriv2
alsriv2's Avatar
Location: Formerly MD and San Diego, now loving life in Arizona
Much better than what a PO did to the bed of my '71 GMC. That PO used a ballpeen hammer on every hole and then filled each crater with bondo. So much damage done that it was cheaper to get a replacement bed.
Alan
2012 Ram 3500 Dually Crew Cab 6.7 Cummins
2014 Palomino Columbus 340RK 5th wheel
'69 Chevy C10 396BB
alsriv2 is offline   Reply With Quote
Thread Tools
Display Modes
