Old 06-12-2015, 01:20 PM   #1
jcblue
jcblue's Avatar
Electric fans wiring options..
I bought a set of electric fans from classic heartbeat.. Nice setup.. And I have my truck wired with american autowire classic update kit.. My question is.. Will it make a difference if I wire the fans to the saw kit that has a fan wire that is basically an ignition wire, or wire it through a thermostat that is supplied in the fan kit from WES. The fans are the only fans, I do not have one on the motor.
jcblue is offline   Reply With Quote
Old 06-12-2015, 01:26 PM   #2
Davidf
Re: Electric fans wiring options..
I bet those fans are going to make a lot of noise. I would wire them through a thermostat controlled relay.
Davidf is offline   Reply With Quote
Old 06-12-2015, 01:34 PM   #3
michael bustamante
michael bustamante's Avatar
yup definatly go thru a relay. and run the power wire directly to the battery if you can.
you could also run a secondary turn on to a toggle switch in case the temp switch ever fails
1967custom
michael bustamante is offline   Reply With Quote
Old 06-12-2015, 01:52 PM   #4
jcblue
jcblue's Avatar
They are not that loud.. I don't think they are as loud as a mechanical fan on motor..
Old 06-12-2015, 02:21 PM   #5
MagmaJct
MagmaJct's Avatar
I've seen how modern vehicles are set up in regards to how they control their fans. They use a staged setup that toggles between, low speed, and high speed. As engine temps rise, the fans are switched on, but in series. This basically runs then at "half" speed. If the temps continue to rise, the relays toggle the fans in parallel causing them to run in "full" speed.
I discovered this when our Uplander would only turn the fans on near overheating. Turns out from the factory, someone inserted the fuse panel in the engine room at a bad angle warping the plastic connector underneath. This caused an open in the series relay. The fans therefor would never come on at their lower speed.
I found it to be an interesting concept. A way to keep noise down except for when maximum cooling is necessary.
Regards,
Mike
I own 3 classic vehicles. 1971 LWB C10 Deluxe. 1974 VW Super Beetle. 1971 VW Fastback.
The C10 and the Super Beetle run, the Fastback is just not there yet!
Please visit my Super Beetle and Fastback profile on TheSamba.
MagmaJct is offline   Reply With Quote
Old 06-12-2015, 02:42 PM   #6
D-rock1981
D-rock1981's Avatar
I have duel fans set up for one to turn on at 190. And the second to turn on at 220 I think. Wired through a dpdt relay and main power wire ran direct to battery.
D-rock1981 is offline   Reply With Quote
Thread Tools
Display Modes
