06-12-2015, 08:25 PM | #1 |
Steering column install question
I'm trying to install my steering column and I want to make sure I'm doing it right. Is the bracket with 2 bolts that attaches to the brake peddle assembly the only thing that holds the column? I made sure the slot indention on the column aligned with the nipple and tightened down the bracket. A couple things look off. One is the shift indicator on the column is not perfectly straight and two the column looks a little high as it goes through the firewall so it pushing up on the gasket a bit. Please let know what you guys think. Thanks
06-12-2015, 08:48 PM | #2 |
Re: Steering column install question
Also a bracket by the brake booster
06-12-2015, 08:58 PM | #3 |
Thread Tools | |
Display Modes | |
