Old 09-04-2003, 05:43 PM   #1
71Seth
71Seth's Avatar
lower control arms (forged or welded) how to tell the diffrence?
97 4x4 1/2 ton. Need to buy lower ball joint but dont know if they are welded or forged. How do you tell the diffrence in the two? They look to be forged at the ball joint but then looks like there is a top and bottom cover weld together to cove it. Someone help me with this. Seth
97 ext cab 4x4
04 pontiac grand am
05 honda rancher AT (yellow)
71' C-10 swb sb400 th350 .040, 292 Mag comp cam, high rise Edelbrock w/750 duel feed Holley, Accel super coil and wires, B&M ratchet shifter
71Seth is offline   Reply With Quote
Old 09-04-2003, 06:35 PM   #2
loweredd
www.loweredd.com
loweredd's Avatar
My MOOG book says to measure the diameter instead if you want.......47.89MM on the forged, and 45.79MM on the stamped.
That is for the pressed in....there is also a bolt it, but it doesnt matter what kind of arm you have. All the bolt in's are the same.
loweredd is offline   Reply With Quote
Old 09-04-2003, 06:36 PM   #3
loweredd
www.loweredd.com
loweredd's Avatar
MOOG # K6509 for 47.89MM forged
MOOG # K6477 for 45.79 stamped
MOOG # K6291 for any bolt in ball joint
Old 09-04-2003, 10:39 PM   #4
71Seth
71Seth's Avatar
thanks a ton loweredd what is the best to use? press or bolt in? Are the factory pressed in or rivited?
97 ext cab 4x4
04 pontiac grand am
Old 09-05-2003, 02:33 AM   #5
loweredd
www.loweredd.com
loweredd's Avatar
Well, I think the easiest to use would be the bolt on.....but......you have to have a bolted on lower ball joint to be able to use that. If you dont have a bolted one, try to find something that will measure that lower one in MM's.
Old 09-05-2003, 05:19 PM   #6
71Seth
71Seth's Avatar
I just had this bad idea of bolts breaking.
I cant mesure until i have them out right. I need to know which(forged or stamped) before so i can get the parts.
97 ext cab 4x4
04 pontiac grand am
Old 09-05-2003, 05:23 PM   #7
loweredd
www.loweredd.com
loweredd's Avatar
You do have a point. You cant drive it while you are measuring......I dont know what to tell you for sure then....
Old 09-06-2003, 09:59 AM   #8
71Seth
71Seth's Avatar
I just dicided that they were welded. Maybe you cantell me about the idler arm with and without the braket. Do i need to install one oith a backet or just the good ole same thing i got now?
97 ext cab 4x4
04 pontiac grand am
Old 09-06-2003, 10:20 AM   #9
loweredd
www.loweredd.com
loweredd's Avatar
MOOG only shows me one without a frame bracket. It's going off of what your truck has now. If someone shows an idler with a bracket, you need to see if you have a bracket on your truck now.
MOOG # K6447 (without frame bracket)
Old 09-07-2003, 10:59 AM   #10
71Seth
71Seth's Avatar
thanks loweredd
97 ext cab 4x4
04 pontiac grand am
Old 09-07-2003, 02:03 PM   #11
loweredd
www.loweredd.com
loweredd's Avatar
No sweat....it's what I do. Hopefully it helps you.
Old 09-07-2003, 05:31 PM   #12
71Seth
71Seth's Avatar
goin to order parts today. should be here Tue. Wish me luck never R/R ball joints on a 4x4 before. Hope it goes smooth.
97 ext cab 4x4
04 pontiac grand am
Thread Tools
Display Modes
