Old 06-16-2015, 12:55 PM   #1
bmtsheets
mechanical to electric oil pressure
Im planning to buy an 84 gauge cluster for my 76 c10.
any advice on swapping over to the electric oil pressure gauge?
I'm going into this without knowing much about these gauges....I just need a working cluster...nothing currently works on my truck.
thanks guys.
bmtsheets is offline   Reply With Quote
Old 06-16-2015, 01:14 PM   #2
mongocanfly
Post Whore
mongocanfly's Avatar
Re: mechanical to electric oil pressure
Do you currently have mechanical gauges? On the 86 dash panel you are getting the electric gauges are operated thru a plug and wired thru the wiring harness..not to mean you can't make it work but you would need to have a basic knowledge of wiring gauges in and installing electric sending units..unless you are restoring/building a show truck I would just run aftermarket mech or electric gauges. You can install aftermarket gauges in the existing gauge holes on you original dash.
Old 06-16-2015, 01:27 PM   #3
bmtsheets
I currently have mechanical gauges. I would reuse my old cluster but its pretty much useless with all of the broken mounting tabs.
Any advice? Im open for anything
Could I just use the 84 shell, and put a 76 circuit board on it and drill out a hole for the mechanical oil pressure and mount it up where the 84 electric inputs go?
I know the speedo cable has an input for a sensor on the 84 too... Im at a loss on what to do.
Old 06-16-2015, 01:42 PM   #4
mongocanfly
Post Whore
Not sure what part of your cluster is broke but you can use the new gauge holder that comes with the gauges and mount them under the dash. Here is what has been done before http://67-72chevytrucks.com/vboard/s...d.php?t=670381
Old 06-16-2015, 05:22 PM   #5
wilkin250r
wilkin250r's Avatar
An 84 gauge cluster on your 76?
The dashboard changed in 81, and instrument panel along with it. Everything from 73-80 is one group, and 81-87 is another. The differences are very subtle, they LOOK similar, but they don't mount exactly the same. It's possible to use different components here and there, but often it requires other changes as well, like wiring the cluster connectors, changes to gauges (as you are seeing) and other things.
In short, this is NOT a simple plug-in application, and might possibly be more hassle than you're willing to undertake.
I know a little about cars, but if you have a question about electricity or sport quads, I'm your man!!!
wilkin250r is offline   Reply With Quote
Old 06-16-2015, 06:11 PM   #6
bmtsheets
I'm pretty glad that you responded before I bought the "73-87" gauge cluster off ebay.
I'm thinking that the Dakota digital gauges will be my most hassle free option.
My current cluster has 2 mounting tabs broken and none of the gauges worked when I bought the truck.....I JUST WANT TO HAVE GAUGES!!!!
Old 06-17-2015, 11:19 AM   #7
wilkin250r
wilkin250r's Avatar
I'm lucky, here on the west coast we have a string of junkyards called Pick-N-Pull, where you bring your own tools and pull your own parts. Their arrangement makes it easy to inspect mutiple vehicles to find intact parts, but it doesn't look like they have a lot in your area.
Not every junkyard is willing to let you browse the lot yourself, but I would ask. To me, that seems a MUCH better option than trying to retrofit a different set of gauges.
Old 06-17-2015, 02:27 PM   #8
1774btcrew
1774btcrew's Avatar
I have a very nice instrument cluster out of a 77 with no broken tabs. Send me a PM if you are interested
AZPartsLocators on Instagram
1972 Cheyenne Super Short Bed big block "Blackie"
1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog"
1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck.
1774btcrew is offline   Reply With Quote
Old 06-17-2015, 11:18 PM   #9
hatzie
Moderator
hatzie's Avatar
Be alert.
The 81-86 cluster plug is terminated differently from the 1976 plug. You'll need to play musical wires.
The TEMP gauge will read differently if you don't get the right 1984 sender for it. I'm not sure where the year splits are but the TEMP senders changed at least twice and maybe three times between 1973 & 1991.
The oil pressure sender should be fairly easy to retrofit. Just use the same cavities in the bulkhead connectors that the 76 OIL lamp uses on the idiot lamp cluster. If you can find a 73-76 base model truck in a pick N pull you can liberate both halves of the oil sender wire that GM used for the OIL lamp. I'd liberate the cluster ground and power wires on a mid 80's truck too.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Thread Tools
Display Modes
