Old 06-16-2015, 05:25 PM   #1
J1MMY
Pinion Angle after axle flip etc and caltracs Q
Finally got the rear axle flipped on my '79 shortbox and once I've sorted notching the frame will be fitting drop shackles and possibly a 1" block.
I'd be interested to hear from anyone who has done similar and if they shimmed, how many degrees etc. I shimmed my S10 last year using JTR parts but have found no concrete info on '73-'87 trucks (lots on '67-'72 in the search facility).
I have looked at the possibility of raising the rear of the trans (M21) but the clearance is not there to allow.
Also, has anyone used caltracs or similar on a slammed full size to stop axle wrap?
'63 C10 Longbox fleetside
'94 C1500 Sierra ex-USAF beater
J1MMY is offline   Reply With Quote
Old 06-16-2015, 06:33 PM   #2
geezer#99
geezer#99's Avatar
Re: Pinion Angle after axle flip etc and caltracs Q
Easy to figure it out.
Info for you!
http://www.drivetrain.com/parts_cata..._problems.html
Or
http://www2.dana.com/pdf/J3311-1-DSSP.pdf
geezer#99 is online now   Reply With Quote
Old 06-16-2015, 06:49 PM   #3
KQQL IT
At the body shop.
KQQL IT's Avatar
Cal trac bars seem like some down pinion angle. Depends on your goals with the truck
" That didnt make it any newer "
" Dont antique the equipment "
KQQL IT is offline   Reply With Quote
Old 06-17-2015, 02:37 PM   #4
Keith Seymore
Keith Seymore's Avatar
This might be a little more to the point:
The concept here is that you will need to measure the u joint working angles as shown above (same as the other attachments), and then do any shimming based on what you learn.
Without doing that you are just shooting in the dark.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Keith Seymore is online now   Reply With Quote
Old 06-17-2015, 03:31 PM   #5
KQQL IT
At the body shop.
KQQL IT's Avatar
Those are fine for daily driver stuff.
the cal tracs seem to like 2 or 3° down. At least my 73 did.
Depends on the goals of the project
Old 06-17-2015, 08:38 PM   #6
Tom
driving is in my blood
Tom's Avatar
I never needed to adjust the pinion angle on my old 79 that was flipped with western chassie parts.
Old 06-17-2015, 08:51 PM   #7
bigblock73
yeller
bigblock73's Avatar
Flip, drop shackles and cal tracks on my 73 swb...didn't need or have to adjust pinion angle.
bigblock73 is offline   Reply With Quote
Old 06-20-2015, 06:38 AM   #8
J1MMY
End goals are not much - running a mild 350 through a 4 spd, looking like @ 8" rear drop and 6 on the front, just want it to be able to put power down well. It is not a daily driver or a hauler, comfort not an issue.
K
A little light reading thank you very much! and thanks to all for the input.
Thread Tools
Display Modes
