Old 09-06-2003, 04:30 PM   #1
CT-Truckster
CT-Truckster's Avatar
blower polishing pics
apparantly i got too much time on my hands so i thought i would polish my blower. never done this before and let me tell ya it's time consuming an tedious. i bought the intake polishing kit from eastwood and it comes with enough stuff to do an intake but i ordered some more abravise tapers too make sure i had enough for the blower. the kit also comes with a can of diamond clear clearcoat. you can see the back plate is what it started out as then the case is after the first round with the 80 grit tapers and the other piece is polished up real shiny now. but i think all the lonely hours out in the garage at night with the air die grinder will be worth it when i get thru.
and you can see here i was doing a little practicing on the manifold
CT-Truckster is offline   Reply With Quote
Old 09-06-2003, 07:24 PM   #2
low 84
low 84's Avatar
cool. so what are the specs for the engine its goin on? and how soon do you think you'll have it in there?
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works
'05 1500 Crew Cab
RIP
'84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker
'80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's
low 84 is offline   Reply With Quote
Old 09-08-2003, 01:03 AM   #3
CT-Truckster
383
144 supercharger, with the pully i got it'll theoretically pump out ~4.5 lbs of boost.
8.5:1 compression, theoretical 10.8:1 effective comp ratio.
441 heads, three angle valve job, ported & polished intake and exhaust.
summit 1103 cam.
I'm also gonna polish the inside of the blower manifold.
holley 750 carb
i figure it should be good for at least 400 horses.
oh and i should have it in in a couple of weeks.
Thread Tools
Display Modes
