07-13-2015, 11:52 PM | #1 |
Pics of your AirRide control system?
My Avs controller is acting up and I'm not a giant fan of handheld wired controllers anyway, so I debated doing an In-Dash switch and gauge set up. I don't plan on expensive or difficult set ups, just 4 switchs and 2 gauges. Any pics of how you did yours? Or any that you've seen and saved? Thanks.
Jack 1968 swb on air |
07-14-2015, 08:03 AM | #2 |
67-72 parts collector,…
Re: Pics of your AirRide control system?
Contact member way2lo2 for a simple manual valve set up.
He's a member?vendor here. http://67-72chevytrucks.com/vboard/s...d.php?t=575686
07-14-2015, 09:14 PM | #3 |
That's almost exactly what i was thinking of. Just wanted to see how other's had done it, will definitely get ahold of him.
10-17-2015, 03:30 AM | #4 |
^^^BUMP^^^ Interested in this as well.
10-18-2015, 10:59 PM | #5 |
Here's a pic of Hales Speed Shops standard setup, had it on 2 of my trucks and have been very happy with it.
'58 Apache |
02-09-2017, 01:47 AM | #6 |
Bump. Still haven't done anything with it,and Accuair's remote is still out of my price range lol.
02-09-2017, 03:37 AM | #7 |
I finally bought the Accuair E-Level setup and love it. Here is where I mounted my controller because I got tired of it sliding round on my bench set. I screwed a metal plate to the back of the controller with 2 very strong magnets stuck on with double sided tape. Then made a plate that slides in between my dash cover and my aluminum overlay that I painted to match the interior. I still need to take it out and paint it. I can pull it off, unplug it and throw it in my pocket, works great. Does not interfere with the door, my knees or anything else. I have rubber pads on the bottom of the magnets so when I paint that plate it won't get scratched too bad.
02-09-2017, 11:11 AM | #8 |
Frequent Flyer
Switch for front, rear, & compressor cut off switch.
I wanted them hidden. I like the "safety rings" on the switch panel for the purpose of easily feeling where your hand is on the switches & would also keep them from being bumped if you had a middle passenger. Dual needle air gauge in lower left corner... visible from drivers seat but very unnoticeable with the door closed. Last edited by JWall; 02-09-2017 at 11:17 AM. |
02-09-2017, 12:39 PM | #9 |
Dual needle gauges (I don't smoke) & manual paddle valve switches under the seat frame...
Thread Tools | |
Display Modes | |
