Old 09-06-2003, 09:34 PM   #1
N2TRUX
Happy to be here
N2TRUX's Avatar
Where's this go?
Ok, trivia time. I'm detailing the 77 today, and ran acros a couple of things I need answers to.
I have a line running out of the back of the carb base plate that is blocked off. I can't find any place that is went to. Does this come capped off from the factory? I know this isn't the way the factory would do it. Maybe someone last the cap, and used this instead....
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 09-06-2003, 09:34 PM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Another view...
Old 09-06-2003, 09:49 PM   #3
phantom dually
Project92 SWB stepside
phantom dually's Avatar
How about a vacuum line for the heat/ac. Alot of trucks used it to open the vacuum canister for vents to sitch from dash to floor etc etc.
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448
phantom dually is offline   Reply With Quote
Old 09-06-2003, 10:08 PM   #4
mike reeh
5 day ban, learn to behave.
mike reeh's Avatar
thats probably not the stock carb. none of my 77s or any quadrajets of mine for that matter, have ever had that hookup. its null & void in your application
mike
mike reeh is offline   Reply With Quote
Old 09-06-2003, 10:16 PM   #5
swervin ervin
You get what you pay for
swervin ervin's Avatar
I think this is the port for the air cleaner. Can't remember for sure. But I believe this hose went to the hot air sensor inside the air cleaner.
If you don't need it, buy a cap to go on it. It will look better than a piece of hose stuck on it. As Mike said, it may be you have a newer Q-jet on there too.
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 09-06-2003, 10:42 PM   #6
N2TRUX
Happy to be here
N2TRUX's Avatar
Nope, it's not that. The hot air sensor is hooked up to another line.
I think mike reeh may be right. Since everything appears to be hooked up and working correctly, I am going to assume it's not supposed to go anywhere. Tomorrow when I go by the auto parts for hose clamps, and plug wire clips, I'll get a vacuum cap too...
Old 09-06-2003, 11:07 PM   #7
mike reeh
mike reeh's Avatar
if you give me the exact specs of your truck (year, engine, state, tonnage, AC, etc) Ill scan in the GM vacuum diagram from the 77 manual..
mike
Old 09-06-2003, 11:20 PM   #8
swervin ervin
After looking at the pic again, I think this port was used for the EGR bleed solenoid on my 85. You don't have a EGR, right? So I say the carb has been swapped out to a later model. Maybe. Could be. Heck I don't know. Cap it with a vacuum cap.
Old 09-06-2003, 11:21 PM   #9
N2TRUX
Happy to be here
N2TRUX's Avatar
That would be cool Mike. It's a 77 Cheyenne with a/c and 350/350 auto. It's a 2wd, 1/2 ton, and it's not a Cali spec truck. What else ya need?
Old 09-07-2003, 12:39 AM   #10
mike reeh
mike reeh's Avatar
interesting. all the california emissions trucks didnt have that connector but apparently your truck may have needed it:
thats for light duty emissions which I would assume your half ton is.. Here is the heavy duty emissions..
hope this helps
Old 09-07-2003, 03:11 AM   #11
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
Maybe a rear vacuum brake? Looks like it was taken off.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 09-07-2003, 10:37 AM   #12
Canadian-Ron
cap it and forget it
my project........... my hell......... http://members.shaw.ca/ronmccoy/
Canadian-Ron is offline   Reply With Quote
Thread Tools
Display Modes
