Old 07-14-2015, 11:08 PM   #1
beanyard
3speed column shift help!!! 1959
Please help if you can. I want to see if it is an adjustment problem before I resort to pulling the tranny. I rear ended some one and had no visual damage to the truck but my ability to shift into 1,2,3 is intermittent. My linkage seems to bind upon visual inspection but I don't know if it is binding inside the tranny. After failing to shift into 1 I was able to get it back in once and went all the way to third with no problems. After stopping and trying to shift to 1 it would not go into gear. ...any thoughts would be greatly appreciated. I don't want to pull the tranny unless I have to.
beanyard is offline   Reply With Quote
Old 07-14-2015, 11:13 PM   #2
beanyard
Here is a pic
Old 07-14-2015, 11:51 PM   #3
mike69c10
Re: 3speed column shift help!!! 1959
Usually this is a sign of slop in the column or linkage. My 69 does it as,well. It won't do it if I go 3,2,1 skip 2 and it binds.
mike69c10 is offline   Reply With Quote
Old 07-15-2015, 01:21 AM   #4
beanyard
Old 07-15-2015, 01:23 AM   #5
beanyard
Thank you mike69! What is the best way to remedy slop in the linkage?
Old 07-20-2015, 11:10 AM   #6
_Ogre
_Ogre's Avatar
Have you replaced all the plastic bushings?
they might have cracked and fallen out
shop air compressor timer
Thread Tools
Display Modes
