Old 07-21-2015, 03:21 PM   #1
Isaiah92260
Isaiah92260's Avatar
How does the wiring work for Horn to steering wheel?
My Horn was installed in to a Press button on the dash. I want to connect it back to the steering wheel. Does anyone know how this works? My truck has two horns that look very old and work as one.
Isaiah92260 is offline   Reply With Quote
Old 07-21-2015, 03:22 PM   #2
Isaiah92260
Re: How does the wiring work for Horn to steering wheel?
Steering wheel
Old 07-21-2015, 03:33 PM   #3
blown240
blown240's Avatar
The horn button supplies ground for the horn relay. Hard to say if your button just provides power for the horns, or if it supplies ground like the original. A few tests would determine that.
ALSO, on my 61 I have the EXACT same old button for my horns. Its mounted under the column though. Same steering wheel too, maybe these had issues. I got my truck from an old guy in Hemet. I wonder if yours and mine were done by the same guy since we are so close to each other....
'61 Panel - Helms Bakery Truck - Daily Driver - FOR SALE
blown240 is offline   Reply With Quote
Old 07-21-2015, 03:34 PM   #4
Softpatch
Softpatch's Avatar
Steering wheel horn button completes the ground on the horn relay
(located on the firewall above steering columb)
My Spelling is Not Incorrect...It's 'Creative'
1966 C-20 .....Swap 91 G-30(5.7 FI)/4L80E
http://67-72chevytrucks.com/vboard/s...d.php?t=789617
59 Viking Revival .. http://67-72chevytrucks.com/vboard/s...d.php?t=632341
Softpatch is offline   Reply With Quote
Old 07-21-2015, 03:44 PM   #5
Isaiah92260
That could be possible. My truck was a ex-police truck in San Diego and then owned by a old Micky mouse dude that neglected that crap out of this truck..
Old 07-21-2015, 03:46 PM   #6
blown240
blown240's Avatar
Gotcha. Mine is a Helms Bakery Panel that was taken pretty good care of, then sat for 20-30 years....
Old 07-21-2015, 03:46 PM   #7
Isaiah92260
Do I need to take off the horn button to re wire the horn? Everything works, I just want the truck to work in its original way
Old 07-21-2015, 03:48 PM   #8
Isaiah92260
Lucky, I just pulled out a rats nest of bad wiring and useless switches the other day. I want to figure out how to wire the orginal temp cage back together. The truck came with a aftermarket guage that's under the dash
Old 07-21-2015, 03:54 PM   #9
blown240
blown240's Avatar
Here are some pics of the wire you need to hook up. Mine is a 61, but I think they are the same.
This is the green wire that goes to the horn button on the steering wheel
This look familiar???
Old 07-21-2015, 04:25 PM   #10
Isaiah92260
I don't see that wire anywhere on my Collum :/ my steering colum is a solid sift too, yours looks a lot different from mine..
Old 07-21-2015, 04:37 PM   #11
blown240
blown240's Avatar
Mine has the shifter on the floor....
You may have to run that wire yourself. Sorry I dont have any pics of whats behind the horn button.
Old 07-21-2015, 05:53 PM   #12
Isaiah92260
Can you show me where on te fuse box that wire connects to? Or does it go straight to the battery?
Old 07-21-2015, 05:58 PM   #13
blown240
blown240's Avatar
That wire doesn't go to the fuse box or the battery. It goes from the horn relay to the horn button. It's a ground wire.
Old 07-21-2015, 06:27 PM   #14
Isaiah92260
So then all I need to do is find where the wire is supposed to run from the horn button on the wheel and run it to the horn relay?
Old 07-21-2015, 09:44 PM   #15
Mackie
Mackie's Avatar
In the mean time everyone's waiting for your charging system update on your other thread.
`63 C-10 Shortwide
Roller 305 LT1 cam, Eddy 500
T5
Mackie is offline   Reply With Quote
Old 07-21-2015, 09:46 PM   #16
Isaiah92260
I havnt had the chance to check the Chsrging system since I've been working over time. I was planning on doing it this weekend
Old 07-22-2015, 11:32 AM   #17
blown240
blown240's Avatar
Theoretically. But you should use a test light and see what that button that was installed is doing. If its supplying ground like the original horn button did, or if its been changed to supply power.
You mentioned that the PO was a tinkerer. I could see a tinkerer running power from the fuse box, thru the button, to the horns. This would basically eliminate the horn relay.
Thread Tools
Display Modes
