Old 07-21-2015, 11:43 PM   #1
Sean C
Duct Liner (Sound Deadener) Removal??
Anyone have a brilliant idea for how I can remove this stuff easily? Used it as a sound deadener, which actually worked pretty well, however I'm getting ready to spray lizard skin, but this stuff is a pain to get off! Any of you clever people know some tricks in this area? My thumbs are killing me so anything helps ha.
Thanks guys!
Sean C is offline   Reply With Quote
Old 07-22-2015, 03:05 AM   #2
BigDan3131
BigDan3131's Avatar
Re: Duct Liner (Sound Deadener) Removal??
A Heat Gun would be the best bet and Harbor Freight has the cheapest one.
Custom Painter/Restoration Specialist
1965 GMC 3/4 Ton LB SOLD?
1964 Chevy El Camino in full restoration
1991 Chevy S10 288K+ miles 2nd Owner SOLD
2020 RAM 1500 Warlock
BigDan3131 is offline   Reply With Quote
Old 07-22-2015, 08:22 AM   #3
Sean C
I assume I'd have to heat the underside of the truck with the gun and hopefully it'll come off easier. Thanks!
Old 07-22-2015, 09:33 AM   #4
ibrown50
ibrown50's Avatar
I used a big hairdryer (don't tell the wife!) to remove the sound proofing from my truck, I heated it from above, doing a small area at a time and peeling it back as I went, it was slow but came up ok
Getting old sucks.............but it sure beats the alternative
ibrown50 is offline   Reply With Quote
Old 07-22-2015, 10:03 AM   #5
cooperhw
cooperhw's Avatar
Gas and a match. Stand way back when you fire the match at it.
Seriously though, you might be able to strip it off with one of the 36grit wheels that go on the die grinder.
"Life is too short to drive a boring vehicle".
Later,
Wayne
cooperhw is offline   Reply With Quote
Old 07-22-2015, 10:16 AM   #6
Mathew21
Mathew21's Avatar
I would agree with a heat gun. Work in small areas at a time. Heat from the top then scrape with a putty knife.
It only has original paint once
Mathew21 is offline   Reply With Quote
Old 07-22-2015, 03:11 PM   #7
Sean C
I considered a grinder of sorts. I think I'll try out the heat gun/putty knife and if that's not working, it might be time for the grinder.
Thanks for all the input guys! I'll post how it goes and I'll be updating my build thread as I finish out the cab
Old 07-22-2015, 11:36 PM   #8
Jim53066
Jim53066's Avatar
A wire brush cup on a 4 inch grinder will eat right through it. BUT, it slings the crap everywhere and it is hard to clean up off your floor after you step on it. Don't ask me how I know that.
Jim
Jim53066 is offline   Reply With Quote
Thread Tools
Display Modes
