07-22-2015, 04:42 PM | #1 |
TBI Frustations
1991 Chevy Blazer K-5, 5.7 TBI OBD 1
From 1 day to the next the truck went to $hit, pardon my french. The truck would idle fine for a while, then died. I decided to change the fuel filter, didn't fix the problem, so I changed the fuel pump, no change. After some more troubleshooting and the proplem becoming worse and not fine I rebuilt the TBI, replaced the IAC, then the MAP, then the TCS, then checked the EGR and cleaned, then cut out the CAT, then changed the plugs, checked Vacuum lines & grounds, NO CODES on the ECM, checked the coil found to be good, TPS checks out good. HELP!!!!!! About to change my insurance coverage to full coverage and dump a gallon of gas on it and watch it burn. |
07-24-2015, 12:59 PM | #2 |
Re: TBI Frustations
check fuel pressure
08-09-2015, 09:51 PM | #3 |
Re: TBI Frustations
try the coolant temp sensor.
09-11-2015, 02:42 PM | #4 |
Re: TBI Frustations
disconnect the o2 sensor and wait until the computer goes to closed loop then it should be fine. Could be a bad o2 sensor. my brother had a 91 caprice that did the same thing. i wired it straight from the computer and bam ran great.
Thread Tools | |
Display Modes | |
