Old 07-28-2015, 01:08 AM   #1
64chevtruck
Please direct me toward threads that cover raising our steering boxes
Hi guys, I have been looking through threads looking for info on raising the steering, The info Ive found is a little vague, Ive seen some guys shorten the steering shaft also for some reason>>?
Do you need to add U joints if you raise the box? Do you still need to notch the upper control arm?
Anyway if someone could even just suggest a build thread Id be glad to go look through it,
Andy
64 C10 Fleetside LB 4 Sp/292 Build http://67-72chevytrucks.com/vboard/s...d.php?t=602438
70 GMC 1500 Fleetside LB 3OT/350 Build http://67-72chevytrucks.com/vboard/s...83#post6767983
76 GMC CCLB Dually Build http://67-72chevytrucks.com/vboard/s...d.php?t=691612
79 GMC 3500 Fleetside LB 454/400
90 Suburban Silverado 4x4 350/700R4
97 1500 Cheyenne Short Fleet 350/5sp
64chevtruck is offline   Reply With Quote
Old 07-28-2015, 01:52 AM   #2
BigDan3131
BigDan3131's Avatar
Re: Please direct me toward threads that cover raising our steering boxes
I don't understand? Why do you want to raise the gearbox? They shorten the shaft when going from manual to power steering and CaptainFab sells an adapter to mount the modern gearbox which moves it up slightly but that's all.
Custom Painter/Restoration Specialist
1965 GMC 3/4 Ton LB SOLD?
1964 Chevy El Camino in full restoration
1991 Chevy S10 288K+ miles 2nd Owner SOLD
2020 RAM 1500 Warlock
BigDan3131 is offline   Reply With Quote
Old 07-28-2015, 02:03 AM   #3
64chevtruck
Ok. Thanks for the info on shortening. I need to raise my steering box so my upper control arm doesn't hit it when I'm aired down. I should have mentioned i sectioned my cm. 1.5. And added bags The box is raised to correct geometry and for clearance.
I just need more info on it.
thanks.
Old 07-28-2015, 07:41 AM   #4
The Rocknrod
Moderator
The Rocknrod's Avatar
Starting at post 321. But at post 325 is what you may want. This is a pancaked cross-member:
http://67-72chevytrucks.com/vboard/s...531177&page=13
Old 07-28-2015, 11:17 AM   #5
64chevtruck
Thank you, Ive been over that thread and missed the pics on the steering shaft Ujoint, Thanks for your time,
Old 07-28-2015, 05:46 PM   #6
rickoner
If you want, check out my build thread to see the approach I took.
rickoner is offline   Reply With Quote
Old 08-04-2015, 11:40 AM   #7
64chevtruck
Thank you I will do that. I don't see a link to your build thread though. How do I find it?
Old 08-04-2015, 12:06 PM   #8
rickoner
http://67-72chevytrucks.com/vboard/s...d.php?t=632826
Old 08-04-2015, 12:38 PM   #9
64chevtruck
thanks M8, Im OMW now, Then out to the shop to execute.
Thread Tools
Display Modes
