Old 09-08-2003, 01:08 AM   #1
highboy_04
highboy_04's Avatar
what gears?
i need some help figuring out what gears i got im my rear end. i just got the rear end and its for my 67 but it came out of a 70. i have the code off the rear....NF3896838. thanks.
'67 c10 350/th350
highboy_04 is offline   Reply With Quote
Old 09-08-2003, 11:04 PM   #2
highboy_04
highboy_04's Avatar
anyone? or if those arent the right number what do i need?
'67 c10 350/th350
Old 09-08-2003, 11:45 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I don't have the code here, but I would just as soon pop the cover off and count the teeth. The oil is probably older than dirt anyways.
Old 09-08-2003, 11:47 PM   #4
highboy_04
highboy_04's Avatar
yeah its probably never been opened. what should i look for when counting teeth?
'67 c10 350/th350
Old 09-09-2003, 12:07 AM   #5
Longhorn Man
To get the gear ratio, count the teeth of the driven gear, and devide it by the drive gear. I hear there are numbers stamped in them, but i have no idea where to look for them.
As for what else to look for, teeth missing, chips, a funny wear patern...fluid with more metal in it than oil.
Old 09-09-2003, 12:14 AM   #6
highboy_04
highboy_04's Avatar
ok cool thanks for the help.
'67 c10 350/th350
Old 09-09-2003, 12:22 AM   #7
Longhorn Man
no problem.
Old 09-09-2003, 03:36 PM   #8
jmanz69
Careful, they attack...
jmanz69's Avatar
The numbers will be stamped along the outside of the ring gear. It will have the ring gear tooth number folloed by the pinion gear tooth number. divide the ring by the pinion and you have your ratio.
jmanz69 is offline   Reply With Quote
Old 09-09-2003, 03:56 PM   #9
Bram
Broke
Bram's Avatar
Just like what Longhorn Man said has been the easiest for me.
Pull the cover and count the teeth on both the ring gear and the pinion gear. Then divide the number on the ring gear by the number on the pinion and this is your ratio. (e.g. 41 teeth on ring gear, 11 teeth on pinion=3.73 gear ratio.) I usually use a soap stone to mark the teeth also.
72CheyenneSuper1ton4x4BigBlock
Bram is offline   Reply With Quote
Old 09-09-2003, 05:59 PM   #10
highboy_04
highboy_04's Avatar
thanks guys
'67 c10 350/th350
Thread Tools
Display Modes
