![]() Join Date: Jun 2015
Axle type
How can I tell if my axle is a "3 carrier" or a "4 carrier" ?
Looking through ring and pinion sets on summit racing and jegs, I see 3:73 gear sets listed under both type 3 and type 4.
68 C10 SSB 383 12 Charger 6.4L 12 Accord 3.5L (Wife's ride) 05 Ram 1500 5.7L My build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=676545 |
#2 | |
![]() Join Date: Apr 2012
Re: Axle type
Not the expert on this, but I believe if it's an original rear end, 3.73's and up (numerically) are a 4. They now make 3.73's that can fit either, since the most common swap is 3.08 to 3.73.
1971 C/10 SWB, 15x8 Rallys, 4.5" X 7" static drop, C-notched, 350/350, 3.73 Posi. .........A 383 and Gear Vendors are on my bucket list. 1972 GMC 4X4 K1500 Survivor - Sold No matter what problems life throws at you, your time on Earth can be incredibly fulfilling and rewarding.....if you just lower your expectations. -Phil Dunphy |
Re: Axle type
Here is a good link for information on carrier breaks
http://www.differentials.com/technic...carrier-breaks |
Re: Axle type
Pretty much just verify what gears your truck has now. 3.73's and lower are 4 series, 3.42's and higher are 3 series carriers. As stated, most gear sizes can be found for both carriers. Best of luck with your search!
#5 | ||
Re: Axle type
leftybass209 says 3.73's & lower are 4" Am I not seeing this right? or what? |
Re: Axle type
They are both saying the same thing. Factory 3.73 and lower gears (higher numerically) use the 4 series case/carrier. Where 3.42 and higher gears (lower numerically) use a 3 series case/carrier.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
Re: Axle type
Re: Axle type
Confused about gear ratios? Go see these guys. That'll help!
Re: Axle type
I'm not entirely sure the gear ratio determines the carrier series.
For example.... This page says 3.08 to 3.90 is 3 series. and 4.10 and higher is 4 series (for cars) but says 3:42 and lower is 3 series for trucks and 3:73 and higher 4 series for trucks. http://www.jegs.com/p/Eaton/Eaton-Po...363&Ntt=750876 This says it's for GM 12 bolt truck axles and supports 3:73 but is a 4 series. http://www.summitracing.com/parts/rmg-4902801/overview/ This says it's for GM 12 bolt truck axles and supports 3:73 but is a 3 series. http://www.summitracing.com/parts/rmg-4900721/overview/ I suppose it's possible that JEGS and summitracing are wrong but...
Re: Axle type
MR Taiboo I thought this site/forum is for people sharing information to one another for HELPING some that need a little helping hand. I don't appreciate the hand slapping you just gave me. I didn't think any thing about your comment was of any taste at all ! ! ! mjgord51
![]() Join Date: Jan 2012
Re: Axle type
My $.02 cents would be spend the $20.00 for a gasket and couple of pints of gear lube to make sure what carrier you have. If the gears are factory the should have GM #'s on them. The carrier should have some casting #'s on it. Before I would order $3/4 hundred dollars of gears/bearings/seals/make sure visually what you have. Get some #'s and if you can't get the info you need on the internet or parts store. Ask the Guys on this site.MOST of them are very knowledgeable!!!
It builds on my intelligence when I make a mistake, Boy am I building on it! '67 C-10,'70 Nova SS ![]() |
#12 | |
Re: Axle type
Don't confuse yourself or waste shipping money buying the wrong gearset. If you are certain the carrier is an OEM piece for a 67-72 carrier, the rule as stated in my first post applies. I hope that clears it up. |
#13 | |
Re: Axle type
#14 |
Re: Axle type
Thank you for a clear understanding of the differences, I also Appreciate a straight answer than a belittling picture. mjgord51
Thread Tools | |
Display Modes | |
