Old 07-31-2015, 04:37 PM   #1
Jimal
Jimal's Avatar
Hybrid power steering pump pressure hose
I need to replace the hoses on my previously installed (and somewhat grubby) power steering setup. I don't know where the P.O. sourced this setup, but the pump end of the fitting has an o-ring while the steering box end is an inverted flare. I've been searching for a hose like this, but everything I'm finding is either o-ring or inverted flare, but not both.
What is going to be my path of least resistance, and adapter on the pump, and adapter on the steering box, or a replacement fitting in the pump?
Any suggestions?
Jimal is offline   Reply With Quote
Old 07-31-2015, 05:54 PM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Hybrid power steering pump pressure hose
You could go to NAPA and have it made. Or a tractor shop if your in a rural area.
Old 07-31-2015, 08:16 PM   #3
Jimal
Jimal's Avatar
I am also considering that option.
Old 08-01-2015, 01:41 AM   #4
Captainfab
60-66 Nut
You will have to either have a hose made, or just change the pressure fitting on the back of the pump. If you choose to change the fitting, be careful, there is a spring behind the fitting.
Old 08-01-2015, 02:45 AM   #5
Kenfuzed
Kenfuzed's Avatar
I had a similar problem. I found a similar hose at O'Reilys. It had a female fitting on one end whereas my original uses male fittings on both ends, so I cut off the end with the female fitting, put on the male fitting from the old, and simply re-flared the tubing. I didn't notice mine using any o-rings.
1966 C10 Short Fleetside
1988 Sportster, 2008 Street Glide
Ken's 1966 C10 build "Red Ale"
Follow on Instgram: @cv_performance
https://instagram.com/cv_performance
Harley Performance Parts: CV Performance (Harley related)
Enjoying the ride!
Kenfuzed is offline   Reply With Quote
Old 08-01-2015, 09:37 AM   #6
Jimal
Jimal's Avatar
I just came back from a shop that makes hydraulic hoses and they quoted me $125 to make up the one hose. Since I can get a hose with flares on both ends from Rock Auto for under $20, I'm going to eliminate the custom hose option. The ironic thing is the first thing I did with my new pump is swap the pressure fitting with the pressure fitting from my old pump, which is when I discovered that they were actually identical.
While I suppose there is probably an adapter to go from the o-ring fitting to a flare, fewer things like that means fewer things to leak. I'm going to my local parts store today to see if they can even get me a pressure fitting with a flare.
Old 08-01-2015, 12:40 PM   #7
61K10
61K10's Avatar
I think i have one if you can't find one.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 08-03-2015, 04:55 PM   #8
Jimal
Jimal's Avatar
I may take you up on that. I don't think I'll be able to source one from a parts store locally, and my schedule doesn't afford me much time to rummage around salvage yards.
Old 08-03-2015, 05:21 PM   #9
argonaut
argonaut's Avatar
You can put -AN adapters on each and make a custom hose with -AN fitting ends for way less than $125. This is how I have done all of my hydroboost setups.
Jason M. @argonaut62
1972 K5 Blazer CST, Turquoise
1966 K20 Short Fleet Pickup, Big Ugly
1964 C10 Short Fleet, Gertrude
2001 Porsche 911 Carrera
1996 Ford Bronco XLT
1980 Jeep Wagoneer
2008 Honda CBR1000RR
2005 Honda RC51
1981 Honda CB750C
No dis-assemble Johnny Five! No dis-assemble!
argonaut is offline   Reply With Quote
Old 08-03-2015, 05:24 PM   #10
61K10
61K10's Avatar
the one i have is rusty,should be ok if bead blasted i think. pm me your add and i will put in the mail if you want it.
1961 chevy K10
Old 08-04-2015, 12:06 PM   #11
chevyrestoguy
chevyrestoguy's Avatar
The early pumps (pre-1987) used the inverted flare fitting. In 1987, GM went to the o-ring style. They make o-ring to inverted flare adapters (Russell), but I'm not real crazy about them because now you have two areas to seal (the o-ring side and the inverted flare side).
You have a couple of options:
1): Replace you o-ring pump with an inverted flare pump and run an inverted flare hose.
2): Keep your current set-up, run an adapter, and have the shop make you an "combo" hose. Note: The adapter moves the hose slightly away from the pump, and it gets really tight against the side of the block and the pressure hose.
3): Swap out the o-ring fitting on the back of the pump with an inverted flare style. I have heard that these will swap out, but I have never tried it.
$125 for a single custom hose is a rip off. I recently did custom hoses for my '64, and the fittings (total of three) cost me $12ea and the hose was $4 a foot. They charged me $2ea for each crimp. The total cost of both my pressure and return hoses was $66. Are there any other hydraulic hose shops in town? Most NAPA stores make custom hoses as well.
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 08-04-2015, 12:18 PM   #12
padresag
as the Captain said just take the pressure fitting from the back of the pump and put in one from an earlier pump. just remember the spring that goes with it. then just run a stock hose.
it is that simple.
ron
padresag is offline   Reply With Quote
Thread Tools
Display Modes
