Old 08-01-2015, 05:19 PM   #1
Atommik
Atommik's Avatar
Door trim panels
I am making my own full door length, door trim panels. I'm using the original style interior door handle and window crank handle and Altman latches. I can see that when I attach the trim panel, the flat bar that connects the inside handle to the latch will rub on the inside of the trim panel causing it to bind while opening the door from the inside. If I make an "edge" around the inside of the door trim panel it would give some clearance, but then I think it would be too hard to attach the inside handle to the shaft because of the thickness of the panel. Any ideas how to solve this dilemma?
Atommik is offline   Reply With Quote
Old 08-01-2015, 05:26 PM   #2
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: Door trim panels
if you use ABS for the panel its not an issue, the abs lets it slide, it will bulge at that point but not to the degree that it looks odd.
dwcsr is offline   Reply With Quote
Old 08-01-2015, 09:55 PM   #3
FiftyTwo
FiftyTwo's Avatar
I had the same problem and I also have the Altman latches. I threw out the flat bars and made small diameter steel rods like your typical car uses. I formed the rods so they lay down into the recessed part of the door, heated about 3/4" on each end with a torch and hammered them flat. Then I drilled holes in the flat ends and mounted them to the door handle and latches. Simple, cheap and they work great. Sorry no pictures.
FiftyTwo is offline   Reply With Quote
Old 08-01-2015, 10:56 PM   #4
Atommik
Atommik's Avatar
Thanks for the input. I will look into both of those ideas. I wonder why the flat bar does not travel in the recessed area on the door frame. Maybe a hold over from a different year, possibly pre fifty one with one piece glass?
Old 08-02-2015, 06:02 PM   #5
solidaxel
solidaxel's Avatar
As I remember did we turn the handle upside down (180*) on one side and it fit into the channel in the door
I have slept since I put the doors together so I may have been dreaming!!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 08-04-2015, 07:31 AM   #6
4DSEVEN
4DSEVEN's Avatar
I built up the area so the linkage could move freely.
4DSEVEN is offline   Reply With Quote
Thread Tools
Display Modes
