Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 08-03-2015, 02:00 AM   #1
Bad61c10
Stereo system from scratch
Hello, I have a 61 c10 and I'm looking to do a complete stereo system on it but this is not my area of expertise, can someone give me a list of all the things I need to complete the system. I have nothing now so I'm starting from the bottom, but I do have a new wiring harness so I can wire this.
Thanks,
Ethan
Bad61c10 is offline   Reply With Quote
Old 08-03-2015, 08:28 AM   #2
corvettejim1968
corvettejim1968's Avatar
Re: Stereo system from scratch
Thanks,
Ethan
head unit- Retro Sound
multi channel amp 5 preferred with built in crossover- JL audio
decent cables- RCA interconnect-speaker-turn-on lead- buy an amp kit
4in coaxial speakers for the dash- depends on the rest of the truck for size
i have 1 ten inch sub
Fat Mat - inside doors ,under dash,cab corners,anyplace you cant see it.
here is my system
Hand Made Factory reproduction A/C vents
text or call 602-361-6421
Website for A/C vents
https://coolc10.com/
corvettejim1968 is offline   Reply With Quote
Old 08-03-2015, 08:31 AM   #3
corvettejim1968
if you do it right it will sound amazing and you wont see a thing.
Old 08-03-2015, 11:52 AM   #4
blown240
blown240's Avatar
Thats a nice setup you have there Jim!
Im just about done with mine. But its not that fancy!
'61 Panel - Helms Bakery Truck - Daily Driver - FOR SALE
blown240 is offline   Reply With Quote
Old 08-03-2015, 01:12 PM   #5
Andy4639
Old member
Andy4639's Avatar
Lightbulb Re: Stereo system from scratch
Never thought about a solenoid for the power cable to the amps. Hmm I may add one to my setup. Interesting.
Here is mine.
2 Memphis gold 10 shallow subs.
2 mid ranges in the dash Memphis golds!
Cab corner mounts that I modified and installed 3 ways in.
Head unit.
I did the hush mat in mine with bubble wrap on top then the carpet. The mat is inside the doors also.
Amps are inside the console and everything is nice and neat inside the truck.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 08-03-2015, 02:29 PM   #6
corvettejim1968
thank you. was not cheap after i install the new Focal tweeters and the 2 monoblock class A Monolithic amps to power them I will have $5,000 invested. I used to compete back in the 90`s and now im getting back into it.
Old 08-03-2015, 07:42 PM   #7
HumphreyMurdoch
HumphreyMurdoch's Avatar
Here's a little tutorial from a different forum. I plan using this idea in my truck.
http://www.jalopyjournal.com/?p=11082
'62 C10 LWB fleet side.
283 w/ a T5
HumphreyMurdoch is offline   Reply With Quote
Old 11-13-2015, 03:24 PM   #8
SCOTI
SCOTI's Avatar
Sub'd in.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Thread Tools
Display Modes
