08-08-2015, 12:41 AM | #1 |
new pinon seal - pinon preload question
So i decided today to change pinon front seal. i did not mark the nut so i will be using and inch lbs spec for this on the pinon nut. My question is when you use the inch lbs torgue needle style wrench, do i do this with the axles in? I have the brakes off and just replaced the outside axle seals also. So i have read that used bearings is 12 inch lbs to turn the pinon, again is this with the axles installed or not?
Thanks for any help!!!! |
08-08-2015, 08:01 AM | #2 |
Re: new pinon seal - pinon preload question
That's done with no ring gear and a new crush sleeve.
Gary 1971 Chevrolet C/10 1951 GMC 100 1977 GMC C15 1955 Chevrolet 3100 |
08-08-2015, 08:17 AM | #3 |
The Dana 44 uses shims instead of a crush collar. The 12 inch/lb spec is not for the nut but for the rotational torque of the pinion gear.
Just tighten the nut up as tight as you can get it.
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
08-08-2015, 08:45 AM | #4 |
What ever the specs call for to tighten the crush collar when installed new, I would tighten it to the same specs or 5 to 10 ft. lbs less as not to crush the collar any more...I've also read to measure the distance the nut is on the threads and return it to the same depth, but that does'nt sound too acurate to me..
Thanks, Joe.. 1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB. Last edited by hamjet; 08-08-2015 at 08:59 AM. |
08-08-2015, 10:46 AM | #5 | |
The torque specification is not really relevant for this repair.
08-08-2015, 07:01 PM | #6 |
Everyone, thanks so much for the advice. I think I good it done. Now to sand blast.....
Thread Tools | |
Display Modes | |
