Old 09-08-2003, 06:54 PM   #1
Class of 69
Class of 69's Avatar
Question T-case adaptor Q
I have a friend who is installing a TH400 into his 4x4, but isn't sure yet which t-case has. He needs an adaptor. Will the same one mate his 400 to a 205, 203, 208?? He will be verifying his t-case soon to purchase an adaptor, but if it fits all NP cases, does anyone have one, with the sleeve, to sell? Thanks!!!
69 GMC K10 ..some restoration required....still..
Class of 69 is offline   Reply With Quote
Old 09-08-2003, 07:10 PM   #2
Blazer1970
Blazer1970's Avatar
Basically, the adapters are all different. Any time you have a different t-case OR transmission, the adapter changes. You need the adapter that goes with your particular t-case/tranny combination. With an NP205/TH400, no sleeve is used. The tranny output shaft engages directly with a female input gear in the transfer case (32 spline).
Blazer1970 is offline   Reply With Quote
Old 09-08-2003, 07:15 PM   #3
Class of 69
OK, I should have also mentioned the TH is out of a 2wd. I'm assuming he will also need a different tailhousing, and maybe an output shaft ??
Old 09-08-2003, 09:31 PM   #4
Richard
I have a brand new TH400-205 adapter available if your friend is interested.
Richard
Old 09-08-2003, 10:56 PM   #5
kwmech
You MAY have to replace depending on the length of the shaft, some of them will slide right together. the biggest problem was stated before in that the t-case will need to be a 32 spline input which may require an input gear, bearing, and the correct snap rings also some machining, depending on what t-case you are starting with. I also have all the parts required for doing the swap.
Old 09-09-2003, 07:21 PM   #6
Class of 69
I didn't see him at work today, but I know he had a TH350 in it before, so I assume that is the t-case he intends to use with the TH400. kwmech, why don't you PM me with what you have, and a price, and I can give it to him next time I see him. Thanks
Old 09-12-2003, 07:32 AM   #7
70Chevy4x4Nut
If you get a NP205 that was coupled to a manual or a TH350, you will have to buy an aftermarket adapter to fit it. You cannot just change the input gear and shaft since the bearing housing and input shaft was bigger on a 205 that had a TH400.
70Chevy4x4Nut is offline   Reply With Quote
Old 09-12-2003, 09:38 PM   #8
kwmech
You can put the parts in AFTER you machine out the front of the case for the larger bearing, been doing it for every bit of 10 years now because of the rarity of the 400/205. Never heard of any aftermarket adaptors myself.
Old 09-12-2003, 11:12 PM   #9
70Chevy4x4Nut
I've heard of Advance Adapters that sells many kind of adapters that can couple trannys and NP's together that normally didn't come that way from the factory, without any mods to the Transfer case. They are very pricey though.
Old 09-13-2003, 01:22 AM   #10
Richard
The adapter that AA sells for this conversion is a new input gear, the larger bearing and an exact copy of the GM adapter. You do have to disasemble and machine the case out for the larger bearing just as kwmech says.
Richard
Old 09-13-2003, 06:38 AM   #11
70Chevy4x4Nut
Thanks for the correction. I guess I didn't look at all the footnotes on their site. Sorry
Thread Tools
Display Modes
