Old 08-13-2015, 11:44 AM   #1
Maximus
Maximus's Avatar
Did the "K5 Blazer" fender emblem change between 69-72?
Hi, random question... my K5 fender emblem on the right side is broken. it just says "K/5" and "ER" the center section broke away.
so I have been casually looking for an original replacement fender emblem that has some original patina to blend in with my truck. one finally came up on flebay so I jumped on it, it arrived and now I have a question. My sheetmetal looks to be all original, however there is no center hole drilled on my fender. There is a long living rust pattern on the inner fender and bottom of the front fender from battery decay that makes me think my fender is original, however the new (used) fender emblem I found has three studs on it to attach, one on each and and one in the middle.
Did the '72 blazers only have a 2-stud fender emblem? is my fender just not what it appears to be? I cant see any filler and the faded paint with the greenish primer bleeding through screams originality...
Maximus is offline   Reply With Quote
Old 08-13-2015, 05:26 PM   #2
hemi43
hemi43's Avatar
Re: Did the "K5 Blazer" fender emblem change between 69-72?
I have the exact same issue. I'm fairly certain my fenders are original, but I don't have that 3rd hole you're talking about. Take a look on my build towards the bottom. Do your fender holes look like mine?
http://67-72chevytrucks.com/vboard/s...d.php?t=676080
hemi43 is offline   Reply With Quote
Old 08-13-2015, 10:28 PM   #3
ls1nova71
ls1nova71's Avatar
Can you post a pic of the backside of the emblem? I have never seen one with 3 studs. My '72 was all original, original paint, and it only had 2 studs on the emblems. I also have a fender off of a '69-70 (not sure the year, but where the emblem was removed there's factory metallic blue paint under it so it's not a 71-72) and it only has 2 holes for the Blazer emblem and the 2 for the engine size. I would have thought the factory would have made all the fenders the same to cut costs so adding a third hole doesn't make sense?
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 08-14-2015, 08:32 PM   #4
richard2717
Equal opportunity joke ofender
richard2717's Avatar
I have one 71 and 3 72 Blazers and all of them had 3 studs on each emblem
Members I have met.
Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb
https://paypal.me/6772GMtruckparts
Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type.
richard2717 is offline   Reply With Quote
Old 08-15-2015, 11:22 AM   #5
BrianBethke
My original 70 has three holes. The middle one is at the top of the B.
BrianBethke is offline   Reply With Quote
Old 08-16-2015, 08:41 PM   #6
too much stuff
Roadtrip!
too much stuff's Avatar
Pretty sure they all had 3 studs on back. The 2 outer holes look to be the same as a custom or cheyenne emblem spacing. (so if you used a pickup fender with that emblem, the middle stud would be in the way...)
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 08-16-2015, 09:59 PM   #7
ls1nova71
ls1nova71's Avatar
Maybe it was a plant thing, kind of like Janesville putting the Deluxe emblems in a weird spot? Looking at the emblems off of my truck, I can see where the middle studs appear to have been broken off. I know for a fact that the truck had never had any paint work done to it and both sides only have two holes.
Thread Tools
Display Modes
