09-09-2003, 09:51 AM | #1 |
Now the others dig........
Q about 60-66 cab to frame grounding
Where on these trucks (63 specifically) would the grounding strap be located from the cab to frame???
68 Chevy C10 Stepside Black Primer 78 GMC Longbed White 09 Chevy Silverado Shortbed Granite Blue LOOKING FOR A 67 4 DOOR IMPALA!!!Just like Sam and Dean Winchester!! 'Cause Mustangs are for p^**#$ and you can fit a body in the trunk of a 67 Impala MEMBER OF THE DRUM BRAKE CLUB Bachelor of Music in Jazz Studies Texas State University-San Marcos, TX Certified Music Educator I hope Mom is up there watching and being my Guardian Angel "I've got a fever.....and the only prescription.....IS MORE COW BELL" -The Legendary: Bruce Dickenson "F#$@ 'em up!!!!!!" -The Legendary: Rogelio Escobar TRUCKY LINKS http://67-72chevytrucks.com/vboard/s...d.php?t=457750 http://67-72chevytrucks.com/vboard/s...d.php?t=461184 http://67-72chevytrucks.com/vboard/s...d.php?t=472848 http://67-72chevytrucks.com/vboard/s...d.php?t=417541 http://67-72chevytrucks.com/vboard/s...d.php?t=477788 |
09-11-2003, 06:11 PM | #2 |
N9PHW
Usually found between the firewall and engine then the engine is grounded to the battery and frame.
"I got it one piece at a time and it didn't cost me a dime..." |
09-12-2003, 10:30 AM | #3 |
thanks, isn't there one that is below the cab around one of the cab mounts???? I know my 68 has one from the cab above the passengers front cab mount which connects to the frame directly below it. None of those on a 63???
-Roger
09-17-2003, 04:15 PM | #4 |
N9PHW
I have never seen a ground strap directly between the cab and frame on any of the 15-20 trucks I have worked on/parted out. Only thing I have found is the strap between motor and body.
09-17-2003, 09:48 PM | #5 |
i dont think they use to realy care about grounding much back then
As the curtain calls, and the cast recedes, I am all that ever was and all that ever will be. In wither and repose this frayed chapter now does close, and fade into neon black |
Thread Tools | |
Display Modes | |
