Old 08-23-2015, 02:23 PM   #1
wjjeeper
wjjeeper's Avatar
Need fuel gauge help
I've searched and read the other threads and can't seem to figure this out from them
65 c10, fuel in the tank, dummy light dash.
-I have a new fuel sending unit and new in cab tank. When the key is on the gas gauge is pegged to full. Removing the ground at the tank doesn't move the gauge. When the truck is off the gauge goes to empty.
-The wire from the fuse panel to the sending unit has power at the sending unit and I have a good ground at the sending unit.
If I put power to the back of the gauge itself it sweeps from empty to full.
What am I missing?
Follow me on Instagram
http://instagram.com/ryno._b
wjjeeper is offline   Reply With Quote
Old 08-23-2015, 03:00 PM   #2
wjjeeper
wjjeeper's Avatar
Re: Need fuel gauge help
pulled the sender and it doesn't seem to work
Old 08-24-2015, 04:58 PM   #3
luvbowties
luvbowties's Avatar
Smile Re: Need fuel gauge help
What am I missing?
Sounds to me that gauge IS working, as it goes from E to F as keyed power is changed.
Please check that wire from gauge to sending unit is not partially rusted thru and grounding along its path between the two--path is likely underneath the sill moldings/floor mat, and wire is brown, iirc.. Happens v-e-r-r-r-y often.
Sam
luvbowties is offline   Reply With Quote
Old 08-24-2015, 05:51 PM   #4
ACK
ACK's Avatar
Is it hooked to the factory gas gauge in the dash cluster or a separate aftermarket gauge? If aftermarket, it's likely a different OHM range, so it's showing full all the time.
My truck ain't dead, it just smells funny.
ACK is offline   Reply With Quote
Old 08-25-2015, 04:00 AM   #5
luvbowties
luvbowties's Avatar
Exclamation Re: Need fuel gauge help
Chev TRUCKS kept 0-30 ohms thru at least 1966--only cars went to 0-90 in 1966. HTH,
Sam
Old 08-25-2015, 07:55 AM   #6
ACK
ACK's Avatar
Sam
Thanks for the correction, above post has been edited.
Old 11-29-2015, 12:38 AM   #7
wjjeeper
wjjeeper's Avatar
To update this thread. Tonight I got to changing the fuel sending unit in the tank and bingo. All works well. Hope this helps someone in the future with the same symptoms.
Thread Tools
Display Modes
