Old 08-25-2015, 10:07 AM   #1
77K10Silverado
77K10Silverado's Avatar
Tips for an LS motor search..?!
So i'm contemplating looking for a donar LS to rebuild. What are the best years and sizes for the LS motor? What and where do I need to look for one? This is for my 77 K10 and I wanna keep it mild (factory LS specs). Any tips are welcomed and appreciated!!
Mike B.
77 K10 - http://67-72chevytrucks.com/vboard/s...=1#post6752641
77K10Silverado is offline   Reply With Quote
Old 08-25-2015, 01:27 PM   #2
77K10Silverado
Re: Tips for an LS motor search..?!
Bump??
Mike B.
Old 08-25-2015, 02:51 PM   #3
mongocanfly
Post Whore
mongocanfly's Avatar
Any good 5.3 or 6.0 ls will work fine..hard to get one before they get gone but craigs list has a few..I know most of my buddies are going thru lkq. Most won't need rebuilding..but I've been told to stay away from the steel head motors..the earlier years 02-03-04-05 are easiest to find. If its dbw you may want to change to dbc..depends on what you get but always get the ecm, maf and accessories with the engine..and if you feel froggy get the wiring harness and if you want dbw get the gas pedal as well
Old 08-25-2015, 03:58 PM   #4
77K10Silverado
Thanks man! That's some good info. Anyone else want to chime in?
Mike B.
Old 08-25-2015, 04:46 PM   #5
tinydb84
tinydb84's Avatar
Check carpart.com
One of the venders here, Pacific Fab, does turn key set ups for a really fair price.
David
Instagram: myfabguy
Old 08-25-2015, 08:44 PM   #6
slowcpe
slowcpe's Avatar
carpart.com is a real good site. I found mine on "toys for big boys" on FB. However it turned out to be for sale from a close friend of a few of my close friends.
Ryan
1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840
1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628
1967/71 Blue SWB C10..SOLD
1977 SWB K10..my grandpa's.....never should have sold
slowcpe is offline   Reply With Quote
Old 08-26-2015, 02:37 AM   #7
andrewmp6
Just keep in mind you should change your trans to something newer like a 4l60e,And doing that you will need a adapter kit to run a older t case.The newer t cases are the wrong side drop.
andrewmp6 is offline   Reply With Quote
Old 08-26-2015, 09:33 AM   #8
king-918
king-918's Avatar
Buy a complete vehicle that way you know everything should match up and that way you can also be sure that you have everything you need
<----Christopher
Oh yeah I'm really a Toyota guy, but had some stuff sitting around.
Oklahoma
king-918 is offline   Reply With Quote
Old 08-26-2015, 10:38 AM   #9
Tilt
If you have the time and space, buying a complete vehicle is a good idea. That way you know everything works together. If you part out what you don't need, most of the time you will make extra money on it to put into you own build. Even if you get a motor with iron heads, you can find newer aluminum 317(and others) heads for dirt cheap.
'83 Silverado Step Side
'85 GMC short bed.
'86 Chevy Step Side Custom Deluxe
LQ9/4L80 swap (SOLD)
Tilt is offline   Reply With Quote
Old 08-26-2015, 03:05 PM   #10
MalibuSSwagon
I bought a wrecked/rotted 2k Silverado for $800, truck was running when I got it, stripped the truck down and sold off all the parts, ended up with a free 5.3L and all the extra parts to do the swap. I used as much as possible from the donor, I even cut up the mandrel bent y-pipe to make the adapter sections to hook to my existing exhaust.
MalibuSSwagon is offline   Reply With Quote
Old 08-26-2015, 07:55 PM   #11
KevinD85
KevinD85's Avatar
http://lsx4u.com/home.html
1986 chevy k10 silverado rust free from oregon 350 crate big cam,headers and 2.5" duals with an x pipe.
2001 subaru 2.5 rs with a full wrx sti swap track car project
1991 Lexus Ls400 rwd drift toy
2012 lexus is350 awd daily driver
KevinD85 is offline   Reply With Quote
Old 08-26-2015, 07:55 PM   #12
KevinD85
KevinD85's Avatar
lots of good info on there
Old 08-27-2015, 09:30 AM   #13
77K10Silverado
Thanks for sll the feedback guys. Im this is helpful to many on here. I'll prob start looking for a complete 4x4 to swap over. I guess new drive shafts will be in order?
Mike B.
Thread Tools
Display Modes
