user # 2756
![]() Join Date: Jun 2001
crossover steering
Who is running it and who's parts? I have it on the 83 I bought, but I am not sure about the amount of threads showing or angles of the ends.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm ![]() |
Re: crossover steering
Ord crossover user. 85 blazer with a dana 60. Post pics of your questionable spots.
I used O.R.D. parts for my Dana 60 high steer with cross over. check out my build thread http://67-72chevytrucks.com/vboard/s...596036&page=15
page 15 |
![]() Join Date: Aug 2008
I got parts to do my crossover and high steer from partsmike.com because it was cheaper that way and I could make it the way I wanted it. I had them machine my right side knuckle and then I made my linkages. I think I used a jeep wagoneer (SJ?) pitman arm, but can't remember exactly..
Jason M. @argonaut62 1972 K5 Blazer CST, Turquoise 1966 K20 Short Fleet Pickup, Big Ugly 1964 C10 Short Fleet, Gertrude 2001 Porsche 911 Carrera 1996 Ford Bronco XLT 1980 Jeep Wagoneer 2008 Honda CBR1000RR 2005 Honda RC51 1981 Honda CB750C No dis-assemble Johnny Five! No dis-assemble! |
user # 2756
Thanks for the replies. I am up Philly for work but will be home Friday and I will post some pics.
Junior Member
Used ORD on my 91 crew. They cut it to length (mine was 8" lift) and I also used the huge tie rod bar n links. Best lifted truck I've ever driven.
1969 impala conv 427 #s loaded. dad bought new 1969 "Judge" RA-3, rare warwick blue/white, #'s 1968 vet convertible #s 427/435 tripower (sold) 1968 belair 2door post #s 427/385 1936 ford 5w coupe dads 1st car 1969 camaro ss (17,xxx) miles Wanted: 69-72 suburban project, 69 camaro convertible. also any big block cars. 69-70 gto judge project. |
mine is ORD stuff as well. d60 arm, TREs, and tube as well as the crossover pitman. its pretty solid stuff. i always recommend a panhard bar to go with crossover to fully realize its beauty.
Ryan
Do recommend the panhard bar with leaf springs D 60 too. |
not to thread-jack but wouldn't the panhard bar fight the leaf springs as it tries to swing in an arc?
yessir. the panhard keeps the axle moving in the same arc as the steering when it is compressing or drooping and that keeps the steering from bump steering
the panhard controls the axle position side to side as the axle moves up and down. the leaf springs arc front to back as they compress so the two motions are not inhibited by one another. the leaves tend to deflect side to side as steering pressure is applied and can make the front feel a little wobbly. it also allows for some bump steer. the panhard makes the leaves more stable and fixes the axle motion so it matches the arc of the steering so bump steer and deflection are eliminated. the deflection is more notable the taller the springs. |
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
Yeah i would run one http://www.sky-manufacturing.com/cgi...=CHEVY-APB-002
#13 |
$350 is a lot for the kit. I will buy the rod, ball end and make my brackets.
Thanks for the info Ryan I will install the panhard rod with the leaf springs. That bump steer sucks on the freeway. |
#14 |
![]() Join Date: Feb 2007
interesting, Ryan, would you mind snapping a pic of your set up please.
Steve 1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's |
#15 |
![]() Here it is. It's not a great representation of the standard Chevy truck. I have a four link and air bags sitting on a Ford d60. It's a bit of hot mess. The concept is basically the same for a leaf spring axle, but you are usually limited in the length you can make the panhard without hitting everything. ideal is equal length panhard and tie rod and matched angle. The angle is the more crucial but the closer to equal length you get the panhard to the tie rod the better it will be. |
#16 |
WOW! That is nice. I bet it drives fantastic.
#17 |
user # 2756
Here's a shot of the front end, looks like GM ends to me. I will get another shot tomorrow.
#18 |
I bought ruffstuff isterts and made all my own. uses dodge 1ton tie rod ends from the 80's, and I used heims for the track bar. drives great.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
#19 |
pics
#20 |
You basically made the ord kit with ruffstuff parts. Ord has the tie rod ends with no plastic or nylon wear insert in them. They are all metal with a preload spring to always keep the joint tight. Much heavier duty than any oem joint.
#21 |
#22 |
user # 2756
Here's some more pics.
#23 |
user # 2756
I will be looking into the panhard bar too. Thanks!
#24 |
user # 2756
Those are stock chevy ends I have, correct?
#25 |
I guess this would require a 2WD steering box? And my sway bar would have to go? Would this pan-hard bar help with Death Wobble too?
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 Last edited by jjzepplin; 09-07-2015 at 08:51 AM. |
Thread Tools | |
Display Modes | |
