Old 09-01-2015, 08:06 PM   #1
LDO
LDO's Avatar
These gaskets ok?
I know alot of folks don't use gaskets on ram horn manifolds but these came with them and I figured I would spray some copper sealer on them and use them.
Are these ok or should I get different ones?
These are my first set of ram horns so I appreciate the input.
LDO is offline   Reply With Quote
Old 09-01-2015, 11:20 PM   #2
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: These gaskets ok?
Those look like the ones for the ends. You should have ones for the double ports in the middle. I would use them, run them a few miles to get some heat in them. Let them cool off and then retorque the bolts.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 09-02-2015, 12:46 AM   #3
Captainfab
60-66 Nut
I agree with chevy_mike. I would use those gaskets and retorque them each time after the first 2 or 3 heat cycles.
Old 09-02-2015, 07:46 AM   #4
LDO
LDO's Avatar
Yes,
I've got the rest of them in a bag for the middle ports. Should I spray that copper gasket stuff on them or just install them dry?
Old 09-02-2015, 08:13 AM   #5
cg285
if your heads and manifolds are flat i wouldn't use them. gm didn't
cg285 is offline   Reply With Quote
Old 09-02-2015, 10:49 AM   #6
chevy_mike
chevy_mike's Avatar
Every factory manifold I have removed, from many different model of Chevy vehicles, always had them, or in some cases what was left of them.
Oh and I have installed them dry.
Old 09-02-2015, 11:10 AM   #7
cg285
chevy, olds, etc.... v8's never had manifold gaskets from the factory back in the 50's, 60's, 70's...
assuming, of course, the op has an engine of that era. otherwise gaskets were aftermarket. if the heads/manifolds are flat they will seal up and last longer without the gaskets. gaskets tend to fail over time
if you insist on using gaskets install dry. you can use something like 3m spray adhesive to hold them in place if you need to.
Old 09-02-2015, 01:55 PM   #8
chevy_mike
chevy_mike's Avatar
Well I guess the original 327 in my first '68 C10 and my original 350 in my '69 Camaro don't count. Both had never had the exhaust manifolds off prior to me pulling the engines.
Old 09-02-2015, 02:08 PM   #9
cg285
i don't want to get into a pissing contest because i really don't care. just stating facts. i worked first in a chevy dealership parts dept then on the line in the 60's to the early 80's and they didn't come in off the car hauler with gaskets on the exh manifolds. exception would be the z28 with headers but if i remember correctly that was a dealer installed option.
Old 09-02-2015, 05:40 PM   #10
AcampoDave
AcampoDave's Avatar
My local machinist says if the manifolds are new or freshly surface and the head mating surface is machined as well tthen you don't need them. But, if your stuff is less than ideal, just use them. That's what they're for.
AcampoDave is offline   Reply With Quote
Thread Tools
Display Modes
