09-03-2015, 12:51 AM | #1 |
60-66 disc brake spindle/rotor combo
I'm in the process of installing disc brakes onto my 66 c10 long bed. Now I have a friend that said he used 1972 spindles with the 72 calipers and a 1991 c2500 six lug rotor on his 1965 c10. I wasnt there to watch the install nor have seen the completed work. Would this rotor even fit on the 72 spindle? If so what bearings would I use? I want to keep my six lug, 15x8 truck rallys for sure.
Thanks for all help. Posted via Mobile Device |
09-03-2015, 01:09 AM | #2 |
60-66 Nut
Re: 60-66 disc brake spindle/rotor combo
While the '88-'98 light duty C2500 6 lug rotors will physically fit the '71-'87 HD spindles, the calipers and pads will not line up with the rotor. There has been previous discussion here on the forum on how to utilize those factory 6 lug rotors and those that have recently tried it, have had camber issues. At this point, if you want 6 lug rotors, your best bet is to use the aftermarket 6 lug rotors with the '71-'87 HD spindles.
09-03-2015, 01:58 AM | #3 | |
09-03-2015, 06:29 AM | #4 |
Best place to get the rotors is Summit. Here is a link tot he FAQ setion at the top of this section.http://67-72chevytrucks.com/vboard/s...d.php?t=646002 Also the Suspension section has this type of question in it also. I have two trucks with the 73-87 complete swap in them and used the aftermarket 6 lug 1 1/4 rotors with great results.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
09-03-2015, 07:27 AM | #5 |
67-72 parts collector,…
There is also NO NEED to use 71-72 spinldes.
This will require many other changes. (balljoints, tie rods, centerlink, etc) Use 63-70 standard or drop spindles for disc brake conversions. They are the same price and are a DIRECT BOLT-ON. All manufacturers make them.
Thread Tools | |
Display Modes | |
