09-08-2015, 01:26 AM | #1 |
Dropped coil Springs
Hello
My Name is Nils and I am new on this Forum. I come from Germany and I have a 1966 Chevy C10 with the 283 V8 and the three on the tree. I restore my Truck since One Year and hope i can drive next Year. Now my Question. My Truck is 99% original and I like that. But i think it would be cool to dropp only the front a little Bit. Is it a Good way to but 2" dropped coils at the front ? Or must change some other Parts like the shocks or the spindels to ? Thank you all and sorry for my englisch Greetings from Germany Nils |
09-08-2015, 02:45 AM | #2 | |
Re: Dropped coil Springs
To answer your question, yes: using 2" drop coil springs is a simple, effective, and efficient method to drop the front 2" in one step, needing no additional alterations. Probably also the easiest method--next to (facetiously!) letting air out of the tires! Every method to achieve that 2" drop can have unwanted side effects. My belief is that using 2", factory made, drop-springs--NOT cutting coils from stock springs--produces the most livable, least noticed unwanted side effects of all the various methods....and I feel pretty certain that I've tried/experienced them all. Welcome again and good luck with this project. Do check your ball joints before and after tension is off your front suspension. If worn, replacing them would not detract from originality; it would be just a normal "maintenance" item. Sam |
09-08-2015, 03:18 AM | #3 | |
Ich heiße Vic. Ich komme aus Kalifornien aber ich in Detschland wohne...I could not imagine what it took to get an original C10 into Germany and TüV approved, however very cool! This website has a lot of information for your truck. To your question. Drop spindles will provide you the drop you are looking for and maintain a good ride. Assuming that the your wheel/tire combo is good, pair the spindle up with a good pair of shocks (Bilstein vielleicht?) and you will be good. Or if you just go with springs, do not go more than 2-3'' as steering geometry could change. Gruß |
09-08-2015, 09:43 AM | #4 |
Thank you verry verry much for the fast answers. A Guy on ebay is selling a set of new dropped Coil Springs 2" from "CPP Performance" with the Number: FCS6102-2. Are the Coils ok ?
I will make some pics from my 66 long bed and my little garage in Germany Thank you all |
09-08-2015, 02:06 PM | #5 |
Nils,
I actually just put CPP 2" drop coils up front and 3" CPP drop coils in rear on my '66. I kept OE A-arms and trailing arms also. Check out my link in my build thread to see, if you want.
63 SWB Stepside --Current Project http://67-72chevytrucks.com/vboard/s...d.php?t=836390 66 SWB Fleetside (Stacy) 350ci/Th400 --Gone http://67-72chevytrucks.com/vboard/s...45#post6595745 67 LWB Fleetside (Annabel)350ci/SM420. 7 Year Restoration --R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=633867 |
09-08-2015, 06:24 PM | #6 |
about to do the same.. do you guys think I can go 3" on the front with stock length shocks? thanks
'66 C10 SWB '64 C2 roadster '38 Indian Scout Flattracker '70 Triumph T120R '81 Laverda Jota |
09-09-2015, 01:57 AM | #7 |
Good morning from Germany .
Have someone a picture of a 60-66 chevy c10 with only 2" dropped coils at the front ? I would like to see the different between the original coils and the dropped. Thank you verry much Nils |
09-09-2015, 11:40 AM | #8 | |
09-09-2015, 12:03 PM | #9 |
Not to be contrary but I would think in your case cutting the spring would be fine.
You are only looking for a 2" drop, which is not much. That equates to a 1" cut on the spring (not 1 coil, but 1"). That would also allow you to work with what you have on hand as opposed to ordering parts and having them delivered to Germany, and saves the cost of purchasing a set of springs. The only cost is a front end alignment after everything is done. I have done probably seven or eight squarebodies by cutting the front coils, plus my Chevelle. My current daily driver was dropped in 1986 in this way and currently has 217,000 miles over 29 years with no issues, so I don't think durability is a problem. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 09-09-2015 at 12:14 PM. |
09-09-2015, 12:32 PM | #10 | |
C/10 Rene 1966 Short Fleet "The Hag" 1967 CST Short Fleet "Dark Poly" 1971 Short Fleet 1970 Jimmy Custom 2 WD "Golden Ticket" 1972 Blazer 2 WD "Retro Blaze" |
09-09-2015, 01:30 PM | #11 | |
09-10-2015, 02:11 AM | #12 |
Good morning,
here are some pics from my Garage and my Truck. Have i nice day |
09-10-2015, 05:24 AM | #13 |
09-10-2015, 03:33 PM | #14 | |
One thing to remember if your springs are the original 49 year old springs they maybe sagging some. If you buy 2" drop springs I don't think it's going to lower your truck a full 2" from where it is now.
It only has original paint once |
09-11-2015, 03:54 AM | #15 | |
I think the Springs are the first one. The look like this If the old Springs are sagging it would be better to but some new in. I like it that the front is deeper / lower than the back like this Picture. Have a nice weekend Greets Nils |
09-11-2015, 08:12 PM | #16 |
Who Me?
Welcome Nils!
I did the cut coil spring mod on a 65 Step and I didnt like the ride after. It was too rough.. I would recommend 2" drop springs.
Steve 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
Thread Tools | |
Display Modes | |
