Old 09-20-2015, 01:15 PM   #1
71_Burb
Question vibration
Hey guys .. new to this forum hope maybe one of ya has experienced my issue ?
1971 suburban with a bit of front end / maybe even total shake at speed. I do have a bit of freeplay in the power steering to the right, the alignment is set all new ball joints and inner outer tie rods, sway bar bushings and shocks. I have not re balanced the wheels yet. Also note that when I hit a bump straight on the front feels like it shakes side to side my next attack is the control arms lol.
thanks in advance for any ideas you may have
Dave
71_Burb is offline   Reply With Quote
Old 09-20-2015, 06:29 PM   #2
panhandler62
Java Mechanic
panhandler62's Avatar
Re: vibration
A funky tire or unbalanced tire can have a huge impact there.
Keith
11 Lincoln MKT -- Momma's wagon
13 G37xS -- middle age crazy car
68 C20 Fleetside -- RIP
Decorating the whole town up at a cost of $27 ....
panhandler62 is offline   Reply With Quote
Old 09-20-2015, 07:24 PM   #3
PGSigns
PGSigns's Avatar
Re: vibration
A bad shock will do it also.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 09-21-2015, 01:52 AM   #4
71_Burb
Re: vibration
Ya I'll balance the tires tomorrow before I leave work tomorrow panhandler62
I already replaced the shocks last week Pgsigns, I think maybe the play in the steering isnt helping even tho it showed corrrect toe when i aligned it maybe I really have the wheels turned a bit when I hit a bump causing the front to shake side to side almost feels as the wheel folds over but the tire pressure is correct.
I appreciate both your response's have a great week ahead
Old 09-21-2015, 06:24 AM   #5
andrewmp6
Re: vibration
How old are the wheel bearings?Is it 2wd or 4x4?
andrewmp6 is offline   Reply With Quote
Old 09-21-2015, 10:55 AM   #6
71_Burb
2 wheel drive and to be honest have no clue. Bought this one a month ago
Just slowly going thru the suspension now ... Before I do my engine swap
Old 09-21-2015, 02:23 PM   #7
zellway
zellway's Avatar
Re: vibration
This is what fixed mine.
Erik
My 69 suburban http://67-72chevytrucks.com/vboard/s...d.php?t=530626
1970 C10 step Project Jiminy http://67-72chevytrucks.com/vboard/s...d.php?t=682647
RUST!? Thats just mother natures way of telling all of us.....MINE!!!!
zellway is offline   Reply With Quote
Old 09-25-2015, 05:24 PM   #8
71_Burb
Re: vibration
Well at least you found your issue Zellway glad that fixed it .. mine already has the one with the polly bushing what I have noticed since balancing the wheels is now the shake only happens in the front when I hit any size bump causing the front to shake side to side annoying as all hell. Next thing for me is to swap out the a-arm bushings all the ball joints and tie rods are done
Old 09-25-2015, 05:40 PM   #9
zellway
zellway's Avatar
Re: vibration
How is the pitman arm and idler? Cab and core mounts? Kinda pulling at strings now. Keep us posted after the "A" arm stuff is installed.
Erik
Old 09-29-2015, 12:04 AM   #10
71_Burb
Talking Re: vibration
Update installed new upper and lower arms from CPP today what a difference still need to re align it and theres still a bit of play in the steering box... note all the cross shafts had mad play and the lower ball joints were notchy as all get out
thanks again for all that replied to the thread appeciate your input
Old 09-29-2015, 07:00 AM   #11
PGSigns
PGSigns's Avatar
Re: vibration
Nice looking setup. Post up how much caster they are able to get on the alignment. Be nice to get 4 or 5 degrees in it.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 09-29-2015, 12:25 PM   #12
71_Burb
Re: vibration
Thanks ... Hey PGSigns they say 5 degs but we will see, I'll keep ya posted
Old 10-21-2015, 01:45 AM   #13
71_Burb
Thumbs up Re: vibration
UPDATE : so I found after all the front end work I did ride is so much better but noticed still had a shake from side to side in the front when i hit a bump. It was all the body bushing up front were shot, installed new core support and main bushings up front huge differance ( I will say the poly is a bit stiff ) but worth the money I appreciate all the input thanks again all
Thread Tools
Display Modes
