09-22-2015, 01:10 AM | #1 |
63 Rochester 4 jet carb kit
I'm pulling my carb and buying a rebuild kit .. Its been sitting to long and carb cleaner is doing nothing to help .. I've found online 2 kits from different manufacturers that include "detailed instructions" .. This will be my first carb and are these kits user friendly or should I take it to a shop ?
09-22-2015, 01:14 AM | #2 |
Re: 63 Rochester 4 jet carb kit
Hey! You're here because you're a truck hobbyist. I vote for doing it yourself because nobody will do it for your truck like you will. Finding an "expert" on the old 4jet might be hard. Carefully pull that thing apart, take lots of pics, read as much as you can, find out what the typical problems are (where they wear or get clogged up, etc.) and set it up as throughly as you can.
09-22-2015, 10:27 PM | #3 |
That's solid advice .. I've seen the kits don't come with new floats so those will be an area of extreme caution while handling and cleaning !!!
09-23-2015, 01:33 AM | #4 |
I wonder if any of the Qjet guys like Cliff carry any 4jet parts.
09-23-2015, 01:50 AM | #5 |
EBay carries a lot of OEM / NOS parts .. And any Carb shop will order it for me
09-23-2015, 12:35 PM | #6 | |
It's Better With Nitro
The one I got was sitting out in the elements for awhile and pretty rusty. I have a friend who does dichromate re-finishing, so when I disassembled everything, I sent him the body, etc. I also went with an electric choke conversion on mine to eliminate the heat exchange and crossover parts. Before: Starting to re-assemble:
10-07-2015, 02:28 AM | #7 |
I pulled the top horn cover off .. If I remove the the float bowl hinge pins will the float balance springs come undone or does it remain as one complete unit with the float bowls ??. .. I would hate to f#+k up the tiny springs
Thread Tools | |
Display Modes | |
