Old 09-22-2015, 02:33 PM   #1
ocejo
ocejo's Avatar
76 swb craigslist find
Hi all, I just acquired this 76 I found on craigslist. It wasn't even listed right, I was skimming through the listings, and there it was posted as an s10. I jumped right on it trying not to show much interest, but I couldn't hold myself much. Looks to me as if it's all there. It's been parked since 2013, seller did not know why as it was the fathers vehicle. I was able to get it to start but carb will starve right away so a $20 fuel pump and $20 carb rebuild kit should get that taken care of. Hopefully after new ignition and misc pieces I can get it smogged.(fingers crossed) No more chant... on to the pictures
ocejo is offline   Reply With Quote
Old 09-23-2015, 01:02 AM   #2
ocejo
ocejo's Avatar
Re: 76 swb craigslist find
engine bay before any work
started working on the carb
Old 09-23-2015, 08:45 AM   #3
flashed
Neat truck and power steering to boot ,you got a good one .
flashed is offline   Reply With Quote
Old 09-30-2015, 02:43 AM   #4
ocejo
ocejo's Avatar
Did a little work on the carb, went with a black finish to start a theme under the hood.
going to need a new primary choke
Old 09-30-2015, 07:51 AM   #5
CrazyQuickDraw
That truck will make a good project! Keep us updated.
CrazyQuickDraw is offline   Reply With Quote
Old 09-30-2015, 09:22 AM   #6
Throckmorton Whump
Nice score!
Throckmorton Whump is offline   Reply With Quote
Old 10-02-2015, 01:40 PM   #7
ocejo
ocejo's Avatar
Wink Re: 76 swb craigslist find
not much new still trying to finish up the carb. I learned by experience why linkages are not painted, they stick!! Ill leave some as is and test it
Old 10-02-2015, 01:51 PM   #8
Matt Man
Matt Man's Avatar
Carb turned out nice!. I hope to one day buy a 73-80 c10 and park it next to my k10!
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11
1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020
67 GMC Stepside Straight six/3 on the tree "The Peach"
2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver
K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934
The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903
Matt Man is offline   Reply With Quote
Old 10-03-2015, 04:50 PM   #9
rusty76
rusty76's Avatar
I'll have to watch this one for sure.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 10-05-2015, 11:51 AM   #10
ocejo
ocejo's Avatar
carb is back in and new fuel pump. next is gas tank removal and cleaning, also flushing the line to the pump.
not the greatest video but I'm happy...
Old 10-14-2015, 12:50 PM   #11
ocejo
ocejo's Avatar
Been ordering parts, getting ready for a budget drop.
still looking for some used drop spindles
anyone know if cutting coils without replacing spindles will affect alignment?
Old 10-22-2015, 11:23 PM   #12
cheap
Yes. The toe-in/toe/out won't typically change all that much, but camber can change noticeably from cutting coils.
cheap is offline   Reply With Quote
Old 10-23-2015, 11:21 AM   #13
slammed427
slammed427's Avatar
Spring drop can be aligned. If you're thinking of cutting coils, don't do more than 1. Here's what 150 miles with 1 cut coil do to low pro 20's.
74 C10 LWB 350/T5 Dropped on 20's
Soon to be Bagged and Injected
84 C35 Crew Cab Dually. 454/400 Dropped a lot.
Instagram: mmmdropp
slammed427 is offline   Reply With Quote
Old 10-23-2015, 12:35 PM   #14
ocejo
ocejo's Avatar
Wow that looks like they came off an import with camber way off.
Old 10-24-2015, 12:34 AM   #15
ocejo
ocejo's Avatar
Is that before or after alignment?
Old 10-24-2015, 10:13 AM   #16
slammed427
slammed427's Avatar
Before. The guy that did the alignment was a truck guy, treated it like it was his own.
Instagram: mmmdropp
Old 10-27-2015, 02:12 PM   #17
ocejo
ocejo's Avatar
Been working on a fuel issue. had to remove the paint from the carb and pull it apart again for another clean up. between the old gas and the paint everything was getting dirty. Carb is now back on but I am still having trouble with idle and startup. I have drained as much of the old gas and filled the tank with 91 octane to compensate the leftover gas still in it.
When cranking the engine it will only run on certain occasions. If I add some gas straight to the carb the truck will start and run. It idles very high if I accelerate it a little and stays accelerated.
I am thinking of replacing the float needle with the original and see what happens.
Old 10-29-2015, 01:52 PM   #18
ocejo
ocejo's Avatar
no luck after replacing the float needles.
any suggestions?
Old 10-29-2015, 03:14 PM   #19
slammed427
slammed427's Avatar
I had that happen with my dually after I replumbed the fuel system. I fed it gas into the carb for a couple minutes until it would stay running. As far as the high idle, your idle screw could be turned up to high.
Instagram: mmmdropp
Old 01-27-2016, 02:56 PM   #20
ocejo
ocejo's Avatar
finally back at it. ended up having a plugged idle tube assembly. It may have gotten plugged with leftover debris or even paint from the rebuild. Next I was having a cold start issue. Well, when I was tinkering with it, I removed the choke rod while I was taking the air horn off and on. Now with the choke on correctly and the idle adjusted it runs great.
And now the sad part, it's going up for sale. I always do this, start a project, let it sit, then fix it to sell.
Old 01-29-2016, 04:44 AM   #21
Odaroloc
Odaroloc's Avatar
No! Why ya sellin it?
1971 GMC Sierra Grande 2500 2wd "Sadiee" Caddy 472/TH400 Project "Sadiee"
1969 Chevy C/10 Build "Maisie" Thread coming soon
Odaroloc is offline   Reply With Quote
Old 01-29-2016, 11:38 AM   #22
ocejo
ocejo's Avatar
I was offered a good deal on a 62 Falcon. can't pass it up. I know I can find a squarebody anytime around here.
Old 01-29-2016, 06:47 PM   #23
Odaroloc
Odaroloc's Avatar
Ah makes sense. Good luck with it!
Old 02-06-2016, 08:21 PM   #24
ocejo
ocejo's Avatar
Ok guys need some help!!!
I am having trouble with the truck idling on a cold start. I have gone through checking that all the choke vacuums are correct. While looking at these ports today i found this ported switch that is not hooked up. Now that makes me wonder if everything else is hooked up right.
Old 02-06-2016, 08:31 PM   #25
ocejo
ocejo's Avatar
see pictures
Thread Tools
Display Modes
