Old 09-12-2003, 10:10 AM   #1
sactoC10
71 DELUX
sactoC10's Avatar
sway bar mount options ? (front)
OK, so while dealing with my front end drop (spindles/springs) I removed the factory option front sway bar. Now it is time to re-install it.
I know that there are shorter mounts available that would bring it closer to the frame, but what is wrong with mounting it directly to the frame, anything?
It seems that if I did not have the factory option sway bar and bought an aftermarket one to install, some manufacturers would have theirs put right on the frame...so why not put the factory one right on the frame.
I am just thinking about this and looking for some input. Thanks!
sactoC10 is offline   Reply With Quote
Old 09-12-2003, 11:17 AM   #2
CoryM
Dont see any reason why you cant mount it to the frame with a bit of work. Just need the get it so that the end are parallel to the ground. Or as close as possible. The factory design really isnt that good. You can also get bars made from a spring shop. THere are just a spring after all.
CoryM
1970 heavy duty C-10 fleetside sport truck. Vancouver B.C. Canada
http://www.geocities.com/chevroletc1070
"Take up our quarrel with the foe:
To you from failing hands we throw
The torch; be yours to hold it high."
Lieutenant Colonel John McCrae, Canadian Army
CoryM is offline   Reply With Quote
Old 09-12-2003, 08:26 PM   #3
Dusti
Not Dusti,just Bob
Dusti's Avatar
It should work without the brackets,I don't see any reason it wouldnt.
Bob W
72 cheyenne super 1/2ton
89 camaro
Dusti is offline   Reply With Quote
Old 09-13-2003, 09:12 AM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
Since I don't know who drives what, help me out here guys. What year truck are we talking about?
Old 09-13-2003, 09:45 AM   #5
sactoC10
71 DELUX
sactoC10's Avatar
I have a 1971 longbed fleetside with the factory optional swaybar that mounts to a bracket that drops the bar about 1-1.5" lower than the frame.
Old 09-13-2003, 11:15 AM   #6
N2TRUX
Happy to be here
N2TRUX's Avatar
Cool. I thought you were referring to a 67-72 truck, but wasn't sure. Since there are quit a few vehicles that mount the sway bar directly to the frame, I can't see why it wouldn't worh either.
I assume the sway bar "stands" are there to improve the angles on a stock height truck...
Old 09-13-2003, 11:53 AM   #7
SCOTI
SCOTI's Avatar
I have the sway bars on both my drivers bolted directly to the frame. My 68 has a 1 1/16" stock 1/2ton bar & my 74 has a 1 1/4" stock HD bar & both use urethane bushings from Energy Suspension (Summitt Racing).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 09-13-2003, 12:09 PM   #8
N2TRUX
Happy to be here
N2TRUX's Avatar
Scoti,
Is this what Keith did to his truck. He told me he had to mod the sway bar mount to make it work. He also said something about flipping the bar over.
Someday, I will have sway bars to worry about how they mount...
Old 09-13-2003, 01:00 PM   #9
SCOTI
SCOTI's Avatar
I believe so.... although I'm not sure about the reason for flipping the bar. When I accidently put mine in upside-down, the bend in the bar would've interfered w/the steering/pitman arc. So my sway bars are installed just like factory GM, minus the frame brackets.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-14-2003, 10:47 AM   #10
sactoC10
71 DELUX
sactoC10's Avatar
Thumbs up
I thought that this would be an OK thing to do, but maybe someone who's done it or seen it can provide some more info?
After removing the rivets in the frame for the stock brackets, then removing the brackets. Is the goal to get the bar positioned exactly where it was before, or have most moved it forward an inch or so to avoid dealing with that curve in the frame?
I can see where flipping the bar over at installation would make sense for my truck.
Old 09-14-2003, 03:08 PM   #11
CoryM
Sacto, the thing you are trying to accomplish is that the bar ends are parallel to the ground. THis is why on a stock truck they added brackets to lower the front of the bar, reducing the angle. Now that your trucks arms are higher, you may not need the bracket. Get it as close as you can. As for the front back/mounting you dont have much choice do you? If you move it forward its not going to fit into the bushings on the arms right? The frame bushings are just round bushings that allow it to pivot a little, so long as the bar is centered in them it doesnt matter what angle you mount them on.
Good Luck.
COryM
Old 09-15-2003, 10:05 AM   #12
sactoC10
71 DELUX
sactoC10's Avatar
Thanks.
No probably not much choice. I didn't get to this over the weekend, was too busy working on my brakes.
Appreciate the input.
Thread Tools
Display Modes
