Old 09-12-2003, 04:09 PM   #1
ronsk10
8 lug swap
how hard is it to change from a 8 lug front and rear to a 5 or 6 lug setup? what is the best donors for this swap it is a 71 c-20. Thanks
ronsk10 is offline   Reply With Quote
Old 09-12-2003, 04:20 PM   #2
2wdBlazer
The Blazer King
2wdBlazer's Avatar
1.Why the heck would you do that? If you lived near me, I grab that 8 lug front off ya.
2. Six lug should bolt in. No 5 lug 4x4's.
72 2wd Blazer. Its the superbichinest, megacoolinest, superflowinest.
2wdBlazer is offline   Reply With Quote
Old 09-12-2003, 04:32 PM   #3
WB72
Before and After
WB72's Avatar
I just bought a 71 C-10 front-end from a bone yard. Upper and lower control arms, spindle, disks, and springs. They just cut the frame and gave me everything for $ 200.00 Canadian. I will put the pieces on and check the ball joints and replace them if needed as well as the tierod ends.
The rear end will just bolt up as well. I got a rebuilt (I checked) 3.73 POSI unit for $ 375.00 Canadian.
You can use all springs, if you want, they are different between a 1/2 and a 3/4 ton. but that is your call.
When I'm done, I will have a 1/2 ton.and it will cost about $650.00 Canadian.
Good Luck, its not that hard, once you find donor trucks.
Not Grandpa's C-20 anymore...
383 Stroker 425HP, 485Ft/Lbs
Lowered 3.5" Front / 5" Rear
66,000 miles.
Alberta, CANADA
WB72 is offline   Reply With Quote
Old 09-12-2003, 04:58 PM   #4
crazy longhorn
Fabricate till you "puke"
I did that swap on my 69 , & upgraded to discs. You can use the 73 up c10 pcs, Just use the corresponding ball joints, & outer tie rod ends. The upper a arms will work with the 1/2 ton balljoints installed, the lowers do need to be swapped for 1/2 ton arms due to the balljoint hole sizing. I used 71-72 lower arms, & peeled the rest of the pcs from a 75 c -10(brakes, lines prop valve, master & all). the brake hoses run a little different on the 73 up trucks (pass through the frame ahead of the crossmember), & the prop valve is mounted to the 1st crossmember. it creates a little more "rework" that way, but gives a wider source of parts. Good luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Thread Tools
Display Modes
