Old 10-03-2015, 06:01 PM   #1
tommys72
tommys72's Avatar
dash brake light
I know we've beat this question to death....but...just did a break job on the rear. New shoes, drums cut, a couple new sections of lines, and two new wheel cylinders... dash light still on! What gives? Are any of sure the light has nothing to do with the parking brake? I know a handful of people have said no, but mine for sure does not work and the light won't go away.
United States Marine Corps 2000-2011
Iraq and Afghanistan veteran
Just living life now and enjoying it and my wife, daughter and son
tommys72 is offline   Reply With Quote
Old 10-03-2015, 06:09 PM   #2
cdowns
cdowns's Avatar
Re: dash brake light
Learn the proper way to bleed your brakes and the pop valve will return to the center and the light goes off// read the factory service manual to learn
Old 10-03-2015, 06:15 PM   #3
chiefcfd
chiefcfd's Avatar
The prop valve is the only thing hooked to the light. Parking brake has no light on these trucks.
1972 Chevy LWB Roadster
1999 Chevy Silverado 2wd
2015 Chevy High Country 4x4 Crew Cab
chiefcfd is offline   Reply With Quote
Old 10-03-2015, 06:30 PM   #4
tommys72
tommys72's Avatar
Believe me, the brakes were bled. There is not one bubble of air in those lines. I didn't think I needed to mention that I bled the brakes, isn't that common sense when doing a brake job? What's a pop valve anyway cdowns?
Old 10-03-2015, 07:00 PM   #5
cdowns
cdowns's Avatar
Bleeding the brakes and bleeding them properly are two differnt things if you've got the light on you did not do it right
Old 10-03-2015, 07:58 PM   #6
LockDoc
The Older Generation
LockDoc's Avatar
Mine was still on when I got the rear brakes finished and bled. Brakes felt good so I started driving it and within 20 or so miles it went out on its own....
LockDoc
Leon
Old 10-03-2015, 09:13 PM   #7
tommys72
tommys72's Avatar
I put probably 40 or so on it the next day, no luck. I'm going to rebleed them tomorrow, if that doesn't work. I'm pulling the bulb out!
Old 10-03-2015, 09:34 PM   #8
purple69
purple69's Avatar
sit in the seat stomp brake pedal hard as you can and light will go off
purple69 is offline   Reply With Quote
Old 10-03-2015, 10:05 PM   #9
leddzepp
Moderator
leddzepp's Avatar
X2. This will often recenter the pin, and the light will go out.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 10-03-2015, 10:16 PM   #10
tommys72
tommys72's Avatar
I've never heard that one before, but I'll give it a try!
Old 10-03-2015, 10:24 PM   #11
LockDoc
LockDoc's Avatar
Just unplug the wire from the prop valve.
LockDoc
Leon
Old 10-03-2015, 11:21 PM   #12
kelsfine69
18 Till I Die
kelsfine69's Avatar
Yup worked for me. One good hard stomp.
2011 GMC Acadia
1969 GMC BBC LS7
2007 GMC Crew Duramax
1987 Camaro Iroc 350 Tuned Port Injection
42000Km
1987 Chevrolet Silverado 350 TBI
1987 Chevrolet Silverado 350 TBI(yes 2)
Take me drunk, I'm too home...
kelsfine69 is offline   Reply With Quote
Old 10-04-2015, 07:01 AM   #13
MikeyMan
The hard stomp on the pedal worked for me also.
MikeyMan is offline   Reply With Quote
Old 10-04-2015, 08:56 AM   #14
tommys72
tommys72's Avatar
Well I'll bleed them again today, just to be sure, then I'll give it stomp and see what happens. Thanks guys
Old 10-13-2015, 01:13 PM   #15
tommys72
tommys72's Avatar
Just an update guys, bled the brakes and the light stayed on. Stomped the pedal and it stayed on. Figured I'd drive it and see what happened, bet I made it 500 yards and the light went off and stayed off
Old 10-13-2015, 03:24 PM   #16
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
"prop" valve = proportioning valve. Even though it was inadvertently called a "pop" valve earlier.
The proportioning valve is mounted just along side the master cylinder.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Thread Tools
Display Modes
