10-06-2015, 07:26 AM | #1 |
Is my upper radiator hose right?
Do I have the correct upper radiator hose or is it turned wrong and just needs to be rotated on the inlet and outlets?
RIZ |
10-06-2015, 07:41 AM | #2 |
Re: Is my upper radiator hose right?
Looks about right for an AC equipped truck. It does that to clear the compressor belt. If you have no plans to restore AC, you could probably use a hose for a non-AC rig.
You can fix that PS bracket hanging in space with a piece of 3/8 pipe cut to fit and a longer exhaust bolt. |
10-06-2015, 08:36 AM | #3 |
Ok, that's what I thought too. I currently have to fan shroud on it and it looks like it goes way too high but it makes sense that it's clearing the compressor. It did have AC but not connected and probably won't go back on.
Does anybody have the correct hose part number for NON-AC ? RIZ ps: that's an old pic.......... the motor looks much better now. |
10-06-2015, 11:44 AM | #4 |
That's exactly how mine is. I have AC as well.
85' GMC Sierra Classic Built 350; Weiand intake, Holley 600, Thumpr Cam Built 350 turbo with shift kit & 2500 Stall Thumpin' away |
10-06-2015, 04:06 PM | #5 |
Looks right to me. Here is mine.
Matt
1984 C10 long bed. Built 383, Lunati VooDoo flat tappet 233/241*(.050) 504/525 lift, Brodix IK200 heads, Edelbrock RPM air gap, Holley 750 DP. 700R4 Trans, with shift kit, and 3000 stall. 3.42 gears. 1993 K2500 ext/LB, 4x4. 3.42's, 4L80E, 6.5 TD, Holset Turbo, Intercooled, modified IP, 4" exhaust |
Thread Tools | |
Display Modes | |
