10-08-2015, 03:09 PM | #1 |
carrier bearing
Could someone tell me what is missing from the bearing? Is it in the correct location and missing a seal, or has it slipped back out of place? I have one in my other truck, but it does resemble this one.
1970 GMC Sierra Grande Custom 2500 265/70/16, th400, 502ht |
10-08-2015, 04:31 PM | #2 |
Re: carrier bearing
That carrier bearing assembly is a clam shell you can replace just the bearing without replacing the housing.
I cant tell from the picture if the bearing is bad or not. |
10-08-2015, 04:32 PM | #3 |
Re: carrier bearing
Hello Waldo,
there is a rubber missing around the bearing. Here´s a link which will help you! http://67-72chevytrucks.com/vboard/s...d.php?t=656307 |
10-08-2015, 04:42 PM | #4 |
Re: carrier bearing
Thanks. It is not loose, and no vibrations or anything. I was greasing the truck and noticed it.
10-09-2015, 08:22 PM | #5 |
the boat guy
Re: carrier bearing
Looks good from here. The stub is splined all of the way to the carrier. Newer slip and stub setups are just splined inside the slip yoke.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
10-09-2015, 08:28 PM | #6 |
Re: carrier bearing
The gap in between the bearing and I guess a cover, shield ,is what I did not think looks normal. That cover or dust shield does not appear to move though. Thanks
10-10-2015, 09:26 AM | #7 |
the boat guy
Re: carrier bearing
The dust shield for the bearing is optional and appears to be properly secured.
10-10-2015, 10:41 AM | #8 |
Re: carrier bearing
Now I understand. Thanks for clarifying that shield
10-11-2015, 11:12 PM | #9 |
Re: carrier bearing
big block truck with a TH400 have these
10-11-2015, 11:14 PM | #10 |
Re: carrier bearing
That is what is was, is. It had a 396.
10-11-2015, 11:15 PM | #11 |
Re: carrier bearing
What is the reasoning behind only big blocks?
10-12-2015, 10:15 AM | #12 |
Re: carrier bearing
Mine with a 350 smallblock have it, too.
10-12-2015, 03:00 PM | #13 |
Re: carrier bearing
I just looked at mine this weekend also. Looks exactly the same as the picture. I couldn't detect any slop or play, but am surprised there is no way to lube it. BTW mine is a 3/4 ton 350/auto custom camper.
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
Thread Tools | |
Display Modes | |
